Need Help - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 02-11-2006, 08:59 PM Thread Starter
Need Help
How do you tighten the tachometer?I removed screw in back,housing moves a little.Is there some way to tighten the tach securely to its brace?
ssmendez is offline
post #2 of 7 (permalink) Old 02-11-2006, 09:52 PM
Dan
I believe both the tach and the speedometer are not supposed to be tightly secured to the frame, or anything else. The are supposed to have some free-play to absorb vibration.
Dan is offline
post #3 of 7 (permalink) Old 02-11-2006, 10:23 PM Thread Starter
Smile Thanks Dan
The tach is just loose.I understand the freeplay to compensate for vibration,but its too loose.
ssmendez is offline
post #4 of 7 (permalink) Old 02-12-2006, 09:53 AM
There is a member (knifemaker) who makes a nice looking stainless steel shroud that goes around both tach and speedo and supports them and keeps them from vibrating around.
whistle clean is offline
post #5 of 7 (permalink) Old 02-12-2006, 11:24 AM
Search Goddess
Dianna's Avatar
The tach tends to wobble a bit more than the speedometer on our bikes. They are held in place by just a single arm bracket and this tends to weaken and break, giving the tach that droopy look. You might check the bracket mounting inside the insturment cluster to see what condition it is in. Some have fixed it with JB Weld, or re-enforced it with a washer.
I added a brace between the speedo and tach with a piece of brushed aluminum L bracket. Just drill the holes in and use the existing screws from the back of the buckets. Also provides a handy spot to mount a clock or voltmeter!
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #6 of 7 (permalink) Old 02-12-2006, 11:34 AM Thread Starter
That is easy and cool.Thanks my play is comming from inside the tach .There must be some sort of screw inside that holds the tach onto the bracket..
ssmendez is offline
post #7 of 7 (permalink) Old 02-13-2006, 09:31 AM
Search Goddess
Dianna's Avatar
There is, and you can take the bucket off and check. It could be one or both of the dampers is/are broken.
http://www.ronayers.com/fiche/400_02...ers/meters.bmp
Good news is, they are fairly inexpensive
Part Number: 92075-1714
Description: DAMPER,METER
Source: KAWASAKI
Price: $4.90
My rule of thumb is, if one is broke the other may follow soon so replace both.
Dianna
Conway, AR
Patriot Guard Rider
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
