ACCT ticking noise? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 09-03-2009, 07:56 PM Thread Starter
ACCT ticking noise?
I hear an irregular ticking sound when the bike is idling. I don't hear it at all except at idle. Could it be the springs are bad on the acct or would I hear ticking all the time if that were the problem? It runs silky smooth.
Thanks
2006 VN750 16,500 miles
accord_guy is offline
post #2 of 8 (permalink) Old 09-03-2009, 08:22 PM
Hoser
junkyardroad's Avatar
Try the Grambo trick. It worked amazingly well on mine. It is also free. Go from there.
1986 VN750A(2) 12224 miles.
junkyardroad is offline
post #3 of 8 (permalink) Old 09-03-2009, 08:24 PM
Chucklehead
dragon159's Avatar
X2 for grambo and go from there ...
Next step would be taking them off and greasing the internals.
"Squirrel Bike" aka Jersey
Rat bike with a good PR agent
shaved and coastered
2 into 1 exhaust
rear 170 and front 110
custom dash with voltmeter
Spitfire windscreen
Plutonium plugs
More to come
dragon159 is offline
post #4 of 8 (permalink) Old 09-03-2009, 09:18 PM Thread Starter
OK I understand the part about tightening the spring and letting it snap back. I don't understand the part about going 1/4 turn further than it snaps back. Am I loosening it then?
post #5 of 8 (permalink) Old 09-03-2009, 10:58 PM
The Professor
lance328's Avatar
After you turn to the right to tighten then let it snap back, turn to the left to apply additional pressure.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #6 of 8 (permalink) Old 09-03-2009, 11:05 PM
fergy's Avatar
When you are "tightening the spring" to let it snap back you are in fact loosening the plunger and backing it away from the cam chain, then letting it snap back into the cam chain by the spring pressure. Then turning the screw a quarter turn in the opposite direction is actually tightening the plunger into the cam chain.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #7 of 8 (permalink) Old 09-04-2009, 08:12 AM Thread Starter
Did the Grambo. Oil dripped out the back ACCT. Is that bad?
Thanks
post #8 of 8 (permalink) Old 09-04-2009, 08:56 AM
fergy's Avatar
No that's normal. It's on the downhill side of the back cyl so you're gona get some oil dripping out of there. Test it yet?
Fergy
2002 VN1500 Classic
SEAFOAM JUNKIE!
fergy is offline
