Hiccup between 5-6k - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 2 (permalink) Old 08-30-2009, 04:29 PM Thread Starter
Hiccup between 5-6k
Hey there guys, got the bike running and have been driving it for a bit. Now I have a new problem, in every gear at whatever given speed, she starts to "miss" or "hiccup" between 5-6k on the tach. Everywhere else is great and in the lower gears its hardly noticable with somewhat heavy acceleration as it goes through that range relatively quickly. But in higher gears there is quite a loss in power, although its still able to accelerate beyond 6k and then picks back up. If you stay between 5-6k in any gear you can tell the power loss. Not sure what else to say havent checked anything yet as I'm not sure where to begin, the carbs should be spotless had 'em out three times because of previous problems.
Appreciate any help.
Thanks, Mak
MacKenzie001 is offline
post #2 of 2 (permalink) Old 08-30-2009, 05:59 PM
Simple Solutions
seebeeare's Avatar
try a lil seafoam.... could be bad gas or somithin gettin ppast the tank and cloggin the jet....
double check all ground connections then connections at coils..... the engine can humm a certain way at a particular rpm to wiggle the ground just enough to not spark...
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
How To Test the Stator
seebeeare is offline
