powder coating - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 08-24-2009, 09:03 AM Thread Starter
powder coating
I have just picked up a powder coater for five bucks at a yard sale, and works great! I want to know if anyone out there knows a safe way to coat one of our gas tanks. And if the powder will stick to bondo. I'm really looking forward to coating alot of parts. I'm not a good painter, so I wanted to do the fenders and tank. Any help would be much appriciated. I don't want to get blown up.lol!
mtncityvulcan is offline
post #2 of 5 (permalink) Old 08-24-2009, 10:06 AM
dirtrack650's Avatar
Powder coating requires baking the media after it's been sprayed.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #3 of 5 (permalink) Old 08-24-2009, 10:51 AM Thread Starter
Yeah, I already have an oven just for curing. I just know how to get all the fumes out of the removed, empty tank. The gun works with static. And thats a no, no! I know people weld on gas tanks all the time. So there has to be a way to do it. Some have suggested filling it with water to displace the fumes. But water would make it explode at 400 deg f. when I cured it. I guess I could drain it after I powder it, if i'm very carefull. Just don't know.
post #4 of 5 (permalink) Old 08-24-2009, 10:59 AM
flitecontrol's Avatar
To prepare my tank for welding, I drained all the gas I could (didn't remove the cap or petcock), soaked up the rest with a rag on a stick, and left it in the hot sun with the cap open for several days (took it inside at night). When I couldn't detect a strong odor of gas any more, it was ready. Some folks have sped up the process by having a hair dryer blow into the tank. Not sure I'd want a spark generating electric motor that close to the fumes coming out of the tank!
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #5 of 5 (permalink) Old 08-24-2009, 11:28 AM
'85 Bobber
drodeo17's Avatar
At one time I was thinking about getting my tank powder coated. The company rep and I talked about fixing the dents and he stated that whatever I used "bondo" wise I had to make sure it was rated for high heat. That should go without saying since you are baking the part at 400 degrees. Hope this helps a little.
Completed
Stripped down to motor and frame
Front- 100/90-19 Avon Wide White Walls (cause I couldn't find the 110's)
Rear- 170/80-15 Avon Wide White Walls
Custom Lowering bracket (no shocks)
Powder coated rims Red
14" Apes (cause they didn't have 16" in)
Custom Seat
Ear Shaved
Aftermarket headlight & tail light
Flat Black Paint
Custom Exhaust with Wrap
New Turn Signals
kuryakyn 6180 Grips with helmet locks
Highway Brackets from ccspinner
Kuryakyn Longhorn Offset Dually Highway Pegs
drodeo17 is offline
Tags
gas tank , paint tank , powdercoat
