TOC stator cover conversion - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 08-23-2009, 09:48 PM Thread Starter
Has anybody done one?? Do you still have to pull the engine first time in to do the retro??
Mastertech is offline
post #2 of 9 (permalink) Old 08-24-2009, 12:04 AM
Yes, you have to pull the engine and remove the outer cover to send to TOC for the machining. Here is full info from their site:
http://www.tocmanufacturing.com/Side_Cover_mod.htm
Hope that helps.
post #3 of 9 (permalink) Old 08-24-2009, 12:49 AM
Well, you do not have to pull the engine, but at least tilt in in the frame, so you can remove the stock cover..
post #4 of 9 (permalink) Old 08-24-2009, 01:16 AM
I stand corrected by KM, but a tilt is only about 10 minutes short of a pull according to a recent thread. So it is still quite a bit of work.
post #5 of 9 (permalink) Old 08-24-2009, 02:40 AM
Pulling the engine and paying $450 for the convenience of not having to pull it again seems like a decision based upon an overly optimistic assessment regarding the length of time a person would own a given VN750, given their pricing in the market.
hammmy is offline
post #6 of 9 (permalink) Old 08-24-2009, 05:14 PM
VN750_DawgsFan's Avatar
I sort of agree with Hammmy. I've thought about doing this but I would have to make absolutely sure that I was going to keep the Vulcan for a very long time for it to be worth the time, cost and effort.
Don't get me wrong, I love my 750, but I've also thought about trading up in a few years.
My daily ride
Metzler ME880s
NGK caps, wires and Iridiums
Coasters (made by Lance328), earshave and rejet with screws turned out 3 turns
Volt gauge w/ custom mounting cup by Lance328 wired into headlight bucket 13.5v-14v
National Cycles Plexistar 2 windshield
DEKA battery
Mutazu GA Black hard bags w/ custom support brackets and relocation brackets made by Lance328
Custom lowers made by Lance328
Vance&Hines Cruzer exhaust pipes
H.I.D. Conversion kit
VN750_DawgsFan is offline
post #7 of 9 (permalink) Old 08-24-2009, 07:31 PM Thread Starter
I have thought about cutting and welding the frame if it ever comes up, has anybody done this??
post #8 of 9 (permalink) Old 08-24-2009, 09:43 PM
flitecontrol's Avatar
EdAlbris has modified his frame. Believe he took a subframe from another bike and welded it into place. Photos are in his gallery.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #9 of 9 (permalink) Old 08-24-2009, 10:09 PM
Hoser
junkyardroad's Avatar
Only if you fabricate a VERY solid jig to hold it all in place prior to cutting.
I would sleeve the frame at the cuts prior to welding them back on, clearances may be tight for getting clean steel and a good weld.
Sooo, unless you already have a frame jig, it would be much faster to pull the motor even if you have access to a complete fab shop.
1986 VN750A(2) 12224 miles.
junkyardroad is offline
