least hideous location for a voltmeter? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 15 (permalink) Old 08-19-2009, 01:50 AM Thread Starter
ive got it all wired up per instructions found here:
http://www.scribd.com/doc/8931489/Di...ck-Power-Relay
awesome by the way. makes it super easy to add more crap should the need for more crap arise.
anyhow, i have a "tractor" voltmeter that i'm looking for a less than ugly location for. where have others located a similar style? pics?
thanks!!!
skaere is offline
post #2 of 15 (permalink) Old 08-19-2009, 02:04 AM
The Professor
lance328's Avatar
thanks!!!
I am sorry you consider our normal location "UGLY" I hope you find the place you like.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 15 (permalink) Old 08-19-2009, 02:07 AM Thread Starter
well, where you have it is the only reasonable place i could find.
problem is, i was attempting to streamline the look. i was tempted to ditch the tacho and go with a speedometer only... hence my frustration. that and i dont have a windshield in front of it so its pretty obvious. where did you get the housing to go around it?
skaere is offline
post #4 of 15 (permalink) Old 08-19-2009, 02:15 AM
The Professor
lance328's Avatar
Get the All in one digital unit w/speedo, tach, temp, fuel, volts and ambient temp.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #5 of 15 (permalink) Old 08-19-2009, 02:19 AM
The Professor
lance328's Avatar
I made the housing from 2" PVC, but you can use the mount in link below.
http://cgi.ebay.com/ebaymotors/Auto-...Q5fAccessories
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #6 of 15 (permalink) Old 08-19-2009, 02:23 AM Thread Starter
its funny that you say that cause i picked up a foot of 2'' PVC to do the same. that and a section of 2 1/8'' exhaust... i'm gonna weigh my options tomorrow.
i dont suppose you had a thread on what you did for the PVC housing? did you paint it, is it capped, etc...
thanks!!
skaere is offline
post #7 of 15 (permalink) Old 08-19-2009, 02:28 AM
The Professor
lance328's Avatar
thanks!!
Capped and painted, I cut a piece in half and put it on a cookie sheet in the oven for 15 min @ 300 . When it was pliable I place a weight on top and let cool in the oven.. I cut to fit and glued w/pvc cement. Made my own bracket also.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #8 of 15 (permalink) Old 08-19-2009, 02:44 AM Thread Starter
im not quite following. cut in half... lengthwise? and heat formed it... to what?
have a picture of the housing?
im all for fabrication in the home.
skaere is offline
post #9 of 15 (permalink) Old 08-19-2009, 02:47 AM
The Professor
lance328's Avatar
For the back cap!!
Cut a 3" piece then cut in half length wise, then heat in oven.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #10 of 15 (permalink) Old 08-19-2009, 02:55 AM Thread Starter
oh! so you essentially made a sheet of PVC from a piece of pipe then glued that to the pipe as an endcap.
what did you paint the PVC with that would stick??
skaere is offline
