Trouble Installing ACCT - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 08-16-2009, 01:41 PM Thread Starter
Rebuilt the ACCT and the ACCT itself seem to be fully operational. The issue I'm having is getting it back into the bike. With the plunger fully extended, it will not seat back into the hole. Am I supposed to compress the plunger before installing the ACCT? It wasn't like that when it came out of the bike. Please advise.
SSGHeath is offline
post #2 of 4 (permalink) Old 08-16-2009, 02:35 PM
The Reanimater
jthill524's Avatar
Location: A Little Town Along I-5 in Northern California
YeS...........Pull the plunger all the was back in, Bolt the ACCT back on the bike, Then release the Plunger slowly,
(Then what I did).........After I released the plunger and it went as far as it would go I gave it a 1/64-1/32 turn tweak just to make sure it was seated in.
Here is instuctions with a Video.......
http://www.tocmanufacturing.com/ACCT...structions.htm
JaY
"Veronica"
2002 VN750 Vulcan
Rebuilt Engine
ACCTs lubed w/TOC Springs
Pick-up Coils Gapped at .018"
Splines Lubed
Deka MF AGM EXT15L Battery
NGK Iridium IX Spark Plugs
R/R Relocation Fix
New Rear Rack
Stock Seat Repadded
Ext-BackRest
jthill524 is offline
post #3 of 4 (permalink) Old 08-16-2009, 03:09 PM Thread Starter
Thanx JT. No more bike chatter. Bike sounds great.
SSGHeath is offline
post #4 of 4 (permalink) Old 08-16-2009, 07:17 PM
And just an FYI...
The plunger was extended when you took the ACCT off because as it was removed, the spring screwed the plunger out, as if it were adjusting it.
Good to hear you got rid of the chatter!!
