Unsure Rebuild - VN700 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 20 (permalink) Old 08-13-2009, 12:22 PM Thread Starter
G3P0's Avatar
I recently aquired an 85 VN700 parts bike with 21k mi, starts right up and idles nice but it has rod knock under load, doesn't shift into 2nd, had it there once & 3rd - 5th came easy, needs fork seals & water pump seal for sure. I'm thinking winter project, would like to lower the rear/rake & chop. Don't know if it's worth the effort without replacing the entire engine/tranny... Any and all opinions/suggestions welcome, this will be my first bike project, but I am a capable shade tree auto tech.
G3P0 is offline
post #2 of 20 (permalink) Old 08-13-2009, 01:00 PM
Simple Solutions
seebeeare's Avatar
im thinking your knock is in relatted to theacct and i think your shifing problem is a spring in the shift pawl both to be fixted for under 50 bucks but its just my initial thought
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
How To Test the Stator
seebeeare is offline
post #3 of 20 (permalink) Old 08-13-2009, 02:01 PM Thread Starter
G3P0's Avatar
Sorry, theacct?
G3P0 is offline
post #4 of 20 (permalink) Old 08-13-2009, 02:08 PM
Simple Solutions
seebeeare's Avatar
auto cam chain tensioner when u are in replacing the water pump seal (mechanical seal ) replace the dampeners while your in there
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
post #5 of 20 (permalink) Old 08-13-2009, 02:20 PM Thread Starter
G3P0's Avatar
hopefully I can start the teardown this weekend
G3P0 is offline
post #6 of 20 (permalink) Old 08-13-2009, 02:36 PM
Simple Solutions
seebeeare's Avatar
befor tear down try grambos trick to see if you cant get the tick out... we'll go from there order a set of case gaskets from cheap cycle parts (clutch side case cover (the bigger one) ,tran cover (with sight window) those 2 for sure but it may aslo be a good idea to get the stator cover as well... it may take a lil time to get u the parts chances are someone here has a spring for ya u may want to order the mechanical seal as well from cheap cycle parts just so u arnt waiting for shipment twice ... usually with that spring it just pops out and u can push it back in but there has been a few cases where they break...
Lance said he had pre made parts list so im sure he'll chime in here in a min to lend a hand... btw Lance can u send me the bookmarks/lists so i can be a click away of givin this info out to?
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
post #7 of 20 (permalink) Old 08-13-2009, 02:56 PM
Here is a link to get heavy duty replacement springs for the ACCT, along with still pics and directions, or a video to see a rebuild of the ACCT.
www.tocmanufacturing.com
They usually solve the problem, but if not, a manual (MCCT) cam chain tensioner is also available here. Other members have modifiied their ACCT into a MCCT for a lot less $$.
There is also a free downloadable Kawi service manual on that site, but it is BIG (117 meg, 2295 pages).
post #8 of 20 (permalink) Old 08-13-2009, 05:17 PM
as i see in your noob post, you got both the 700 and 750, ride the heck out of the 750, and rat/chop/and bob away at the 700.... even if you need another engine.... wich i doubt... you will still be way under budget and set on having a good reliable chopper.
post #9 of 20 (permalink) Old 08-13-2009, 07:54 PM
The Reanimater
jthill524's Avatar
Location: A Little Town Along I-5 in Northern California
Here is what I ordered for my Engine Rebuild........
2 92081-1380 - SPRING,TENSIONER Kawasaki [email protected] $5.02
2 11004-1135 - GASKET-HEAD Kawasaki [email protected] $40.24
2 11060-1083 - GASKET,SEPARATER COVE Kawasaki [email protected] $4.62
1 49063-1057 - SEAL-MECHANICAL Kawasaki [email protected] $18.87
1 670d1509 - O RING Kawasaki [email protected] $1.71
2 14043-1056 - FILTER,OIL Kawasaki [email protected] $7.54
2 92055-049 - "0" RING,31MM Kawasaki [email protected] $2.96
2 92055-1272 - RING-O,27.7MM Kawasaki [email protected] $3.84
2 92081-1776 - SPRING,OIL FILTER Kawasaki [email protected] $3.84
2 11060-1361 - GASKET,CYLINDER BASE Kawasaki [email protected] $9.90
2 13008-1077 - RING-SET-PISTON,STD Kawasaki [email protected] $52.58
1 11060-1088 - GASKET,CLUTCH OUTSIDE Kawasaki [email protected] $5.55
1 11060-1089 - GASKET,GENERATOR COVE Kawasaki [email protected] $10.64
1 11060-1090 - GASKET,CLUTCH COVER Kawasaki [email protected] $12.36
1 11060-1091 - GASKET,TRANSMISSION C Kawasaki [email protected] $3.81
1 11060-1086 - GASKET,GEAR CASE Kawasaki [email protected] $7.12
1 11060-1092 - GASKET,OIL FILTER Kawasaki [email protected] $3.27
1 92055-1021 - "0" RING,METER GEAR Kawasaki [email protected] $2.31
1 670D2020 - O RING Kawasaki [email protected] $2.19
4 92055-1308 - RING-O,19MM Kawasaki [email protected] $7.68
2 670B2014 - "O" RING,14MM Kawasaki [email protected] $1.02
1 670D1509 - O RING Kawasaki [email protected] $1.63
4 92075-1747 - DAMPER Kawasaki [email protected] $20.44
2 92075-1748 - DAMPER Kawasaki [email protected] $12.24
2 11060-1119 - GASKET,EXHAUST PIPE Kawasaki [email protected] $7.42
JaY
"Veronica"
2002 VN750 Vulcan
Rebuilt Engine
ACCTs lubed w/TOC Springs
Pick-up Coils Gapped at .018"
Splines Lubed
Deka MF AGM EXT15L Battery
NGK Iridium IX Spark Plugs
R/R Relocation Fix
New Rear Rack
Stock Seat Repadded
Ext-BackRest
jthill524 is offline
post #10 of 20 (permalink) Old 08-13-2009, 09:23 PM
Simple Solutions
seebeeare's Avatar
woa jt dont scare him off yet i was goin for the gaskets and orings to pull the cases we are hopin to fix this without all that tearing apart... thanx for bein on the ball ...
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
