rather odd question... but here goes - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 08-12-2009, 12:05 AM Thread Starter
so, when i built a new batt box and relocated the junction/fuse box i bolted it to the battery box through the rubber "isolation thing" (i drilled a hole in the rubber but the JB already has a hole in it for the rubber to sit in)
this a problem? it seems to me that the integrity of the JB should be intact since i used an existing hole... why is it mounted in that rubber thing anyhow?
skaere is offline
post #2 of 3 (permalink) Old 08-12-2009, 01:28 AM
[QUOTE=skaere;111079]so, when i built a new batt box and relocated the junction/fuse box i bolted it to the battery box through the rubber "isolation thing" (i drilled a hole in the rubber but the JB already has a hole in it for the rubber to sit in)
this a problem? it seems to me that the integrity of the JB should be intact since i used an existing hole... why is it mounted in that rubber thing anyhow?[/QUOTE]
I think it is to dampen vibrations, to help the JB live longer.
post #3 of 3 (permalink) Old 08-12-2009, 04:59 AM
OlHoss, you hit it right on the head...the rubber is there to keep the J/B from vibrating all the delicate diodes and relays to smithereens
