Coaster - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 08-08-2009, 12:44 PM Thread Starter
Richmond, VA
Coaster
So I went to coaster her and it turns out the previous owner snapped off one bolt head at the block on the left side. The I did one on the right but out from the block. Any suggestions on getting these out? Tried to drill and use an extractor but I can't get a good bite on it.
Rodd
'95
mine 05/09 19.5k; 11/09 30k
DONE
RAM Mount
Kuryakyn 12 volt socket
mirrors
paint Speedo and Tach
LED turn sigs
LED Brake
KAW luggage rack
Spiders Den Laptop Bag
KAW Saddlebag kit
Bridgestone Exedras
Protac Backrest
JJCyclepass
Kuryakyn Levers, Grips & Throttle Boss
Spencer seat w/B&H cover
new ignition switch
handlebar clock
cup holder
Mutazu bags
LED Bulbs
New Fuel Tank & Fenders
windscreen
TO DO
Hiway pegs
Rodd is offline
post #2 of 4 (permalink) Old 08-08-2009, 12:49 PM
flitecontrol's Avatar
Are you using the right size drill bit for the extractor? If yes, normally the extractor will engage the wall of the bolt and either remove it, or worse, snap off. Have you used penetrating fluid on it for 12-24 hours?
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is online now
post #3 of 4 (permalink) Old 08-08-2009, 05:56 PM
Whatever you do, don`t snap off the extractor! It`s tool steel and is as hard as a drill bit. I believe that CRC has a freezing penetrating oil with freon or some sort of refrigerant in it. You might try spraying some of that on the end of the bolt when the engine is hot. The thermal shock may crack the corrosion between the threads.
If you destroy the threads drilling the bolt out, you can always repair it with a helicoil.
post #4 of 4 (permalink) Old 08-08-2009, 06:35 PM
Originally Posted by OlHossCanada View Post
Whatever you do, don`t snap off the extractor! It`s tool steel and is as hard as a drill bit. If you destroy the threads, you can always repair it with a helicoil.
I'll go along with OHC on the hard extractor, if you snap it off and can't back it out it is one hard hombrey to work around...
