how hot - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 20 (permalink) Old 08-05-2009, 10:31 PM Thread Starter
how hot
rode about 50 miles today, mostly at 65-75MPH, around 4-5K on the tach. the engine was HOT (not so much on the gauge but it burned my legs on the foot pegs)
the fan never kicked on even above the halfway point on the gauge. again, never reached past 3/4 of the white...
this normal? i checked the coolant level before i left, seemed good to go.
thanks!
skaere is offline
post #2 of 20 (permalink) Old 08-05-2009, 10:45 PM
dirtrack650's Avatar
I'd be checking something. I did a ride last week when the air temp was 102 and my fan kicked in quite often. It always turns on when I stop at a light or when I turn off the engine.
Anyone use the products that claim to lower the coolant temps like 20 below?
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #3 of 20 (permalink) Old 08-06-2009, 06:35 AM
750Doug's Avatar
I think Cindy has mentioned using some liquid ice thing before...
750Doug is offline
post #4 of 20 (permalink) Old 08-06-2009, 07:57 AM
Thats a bit hot I think, check the fan as it should be kicking in especially when stopped, but also the thermostat if you have fluids... I don't think that when you are moving it should get hot past the 1/2 way point to speak of, and if the fan was kicking in even when stopped...
I tried some coolant stuff I got at china-mart, but didn't think it helped as it said it would (15-20*)... I couldn't tell any difference hardlt at all, but I can't remember what the brand was...
post #5 of 20 (permalink) Old 08-06-2009, 08:04 AM Thread Starter
to be honest, im not even sure ive ever seen the fan kick on.
is troubleshooting the fan/cooling system in the verses? ideally i want to start with easiest/most common probs first.
skaere is offline
post #6 of 20 (permalink) Old 08-06-2009, 08:20 AM
I don't mean to state the obvious but make sure your temp gauge is working properly as well.
There are a couple ways to manage engine temp while you're riding too. You can try those if she's over heating. Coasting downhill with the clutch pulled in, pausing for a few seconds between upshifts (if you have room on the road of course), and trying to keep the rpms around 31 or 3200 regardless of gear or speed may help...
LibertyPilot is offline
post #7 of 20 (permalink) Old 08-06-2009, 09:43 AM
spiral_72's Avatar
My fans run at between 1/4 and 1/3 temp on the guage. It's never been over half and that was a 3000ft climb in about 15 miles, two passengers.
First step is pull the connector off the fan and jump 12V to it..... see if the fan even works.
spiral_72 is offline
post #8 of 20 (permalink) Old 08-06-2009, 11:44 AM
ohio_redneck75's Avatar
i use engine ice it comes in a 1/2 gallon and is 17 bucks but it works great. i use in in my
05 750 brute force. its a mud bike and i run it damm hard. keeps it bout 20 to 30* cooler
ohio_redneck75 is offline
post #9 of 20 (permalink) Old 08-08-2009, 10:10 AM Thread Starter
i jumped the fan directly, kicked on perfect.
i assume now the switch comes out and do the boil/conductivity test?
skaere is offline
post #10 of 20 (permalink) Old 08-08-2009, 06:11 PM
You might try turning the switch in and out a few times (to clean off any corrosion) and cleaning the electrical connecton, then go for a ride to test it first. If the fan still doesn`t work, then do the boil test.
