so... marbled now, can i remove the Air Actuated Valve under the seat? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 08-04-2009, 12:56 PM Thread Starter
i plugged both reed valve hoses to the cyl and the little vac hose on the AAV, but there is one large one going up under the tank to the airbox maybe? do i have to plug that one as well or can i just take the AAV out??
thanks!
skaere is offline
post #2 of 8 (permalink) Old 08-04-2009, 01:02 PM
Simple Solutions
seebeeare's Avatar
u can eliminate all that just plug the nipple on the carb or at the end of the lil vac line .... only things the carb needs is 2 in fuel line one vac line to tank and the vent for the carbs the rest can be removed .... i used bid vac caps for my reed valves and eleminated everything else (i also ear shaved)
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
How To Test the Stator
seebeeare is offline
post #3 of 8 (permalink) Old 08-04-2009, 01:03 PM
Simple Solutions
seebeeare's Avatar
the hose that goes to the air box is the air inlet in that system.. since the system has been blocked that hose is no longer needed
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
post #4 of 8 (permalink) Old 08-04-2009, 01:04 PM Thread Starter
that was quick, i love this site.
what about the large hose that goes up under the tank from the AAV? plug or leave it open? (on the AAV there are two 5/8'' hoses to the reed valves, and one larger one that goes up under the tank)
thanks!
EDITED:
gotcha! thanks a ton!!!!
skaere is offline
post #5 of 8 (permalink) Old 08-04-2009, 01:24 PM
The Professor
lance328's Avatar
thanks!
EDITED:
Block the hose going to the surge tank, and rear carb vac port.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #6 of 8 (permalink) Old 08-04-2009, 01:25 PM Thread Starter
aw geez. now whats the surge tank? i can only assume thats the airbox hose
so pretty much block all the hoses from the AAV and ditch it, correct?
skaere is offline
post #7 of 8 (permalink) Old 08-04-2009, 01:27 PM
The Professor
lance328's Avatar
Correct!!
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #8 of 8 (permalink) Old 08-04-2009, 02:36 PM Thread Starter
hrmmm....
so, marbled now. and turned the fuel mix screws out to 2.5 turns, still backfires on decel. up to 3, still like a popcorn maker. 3.25, still (in fact, perhaps more backfiring)
any ideas?
EDITED: forgot to mention that the PO had installed V+H pipes and degoated
skaere is offline
