temperatue gauge problem - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 07-13-2009, 08:24 PM Thread Starter
I searched the verses and couldn't find any information on my problem. My temperature gauge is acting iradically. First it will go up to just about normal then fall back down to cold. It never displays hot enough. Any ideas?
Thanks.
lbcole0915 is offline
post #2 of 3 (permalink) Old 07-13-2009, 10:29 PM
Wiggle the connector wire. You can probably get to it by removing the right side cover that covers the radiator cap. 2 + phillips screws.
post #3 of 3 (permalink) Old 07-13-2009, 10:34 PM
The Professor
lance328's Avatar
It can only be four things.
1: Bad sensor
2: loose or bad ground wire on sensor
3: loose or bad possitive wire at the gauge
4: bad gauge
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
