What's the deal about the swing-arm caps? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 21 (permalink) Old 06-26-2009, 07:55 PM Thread Starter
kontiki's Avatar
Do these things just fall off? (that's ridiculous ... talk about ridiculous ....government trying to pass a law to change the climate of the earth lol,.. but i digress!~)
I don't want to lose mine if I can help it, is it as inevitable as as I am hearing? Any advice?
Thanks guys.
Scott
1996 Vulcan 750
1980 XJ650 Maxim
kontiki is offline
post #2 of 21 (permalink) Old 06-26-2009, 08:10 PM
The Professor
lance328's Avatar
Thanks guys.
Scott
Remove the caps then install them with silicone.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 21 (permalink) Old 06-26-2009, 08:15 PM
I lost one swing arm cap and haven't found a replacement yet. I been checking e-bay for one but had no luck so far.
John Brisson is offline
post #4 of 21 (permalink) Old 06-26-2009, 08:28 PM
Love My Baby
rubyrick's Avatar
I lost one and bought two at CheapCycleParts.com but they don't fit. I siliconed them in place with the bottom portion of the cap not properly seated, and you can't tell. They haven't moved and I did this 6 months ago.
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
post #5 of 21 (permalink) Old 06-26-2009, 09:20 PM
IMBoring25's Avatar
I got one from ronayers.com. It's part number 11012-1433. The description is "Cap Swing Arm"...If you just get "Cap," you transposed a digit and will get a boomerang-shaped piece for an ATV, not that I'd know anybody who would do that.
The price I paid for the cap was $8.96, but shipping is brutal on a cheap piece if you don't find something else you also need to order along with it.
Mine fit fine. Smear some silicone on the OD of the flange of the cap, slide it into the recess, and tap lightly all around the outside with a rubber mallet.
IMBoring25 is offline
post #6 of 21 (permalink) Old 06-26-2009, 10:14 PM
IronMan750's Avatar
Hey John B, I found a pair of swing arm caps on eBay just now. I don't know how to link a webpage but the eBay item# is 370221078162. Hope this helps.
I silconed mine on too almost a year ago and so far so good! Later....
2003
*Battery connected at both ends!
*Real air in the tires
*New Registration sticker
*Seat wiped off
*Low AND Hi beam headlight!
*New #1157 tail light bulb
*Brake pedal still on the right
*Custom valve stem caps made from black plastic!
*Custom built ignition key from Kawasaki
Does anybody really care?
"When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car"
IronMan750 is offline
post #7 of 21 (permalink) Old 06-26-2009, 10:40 PM
IMBoring25's Avatar
I was looking at a few other things and just noticed those too.
http://cgi.ebay.com/ebaymotors/Kawas...171|240%3A1318
post #8 of 21 (permalink) Old 06-26-2009, 10:43 PM
Yes. And more than likely they will fall off in colder tempature. I had a 2002 that I bought new, and the caps were sitting on the floor of my garage 18 months after I bought the bike.
The suggestions on using silicone sealant to hold them on are the standard fix. This allows you to pry them off if need be, but will pretty much hold them on forever.
You of course can order the parts through your local Kaw dealer and not have to pay shipping costs, if you end up losing one, (or both)
post #9 of 21 (permalink) Old 06-26-2009, 11:07 PM
95VN750's Avatar
I lost two due to the cold and got replacements from my local Kaw Dealer for $10 each and since then I have also siliconed them in place and they are still there!!
1980 440LTD
1976 KZ900
1995 VN750 19,500 miles ( start of '08 season ) All mine!
Can't have too many Kaws!
95VN750 is offline
post #10 of 21 (permalink) Old 06-27-2009, 11:22 AM
Joem's Avatar
I didn't even know I was missing them for a long time, until I saw another 750 in person. At first it won't seem like they even fit. If you try to just pop them into the opening they will pop right back out. Put the silicone adhesive around the edge then duct-tape them in tightly overnight. Mine are still there two years later.
Joe McAdoo
Springfield, MO
[email protected]
VROC # 28175
Joem is offline
