Whats this indication light ? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 17 (permalink) Old 06-11-2009, 05:46 PM Thread Starter
Hi all
I got my 1989 vn750 on monday and yesterday took it for its MOT after it had passed its test i took it for a ride but as it was raining hard, not too far.
On the way back i noticed a light come on briefly, on the instrument cluster the one that came on was the bottom right hand side one. What i dont know is what it means as the writing on that one is in japanese on a red cover ( which is strange as all the others are in english ) I wasnt too sure if it was something to do with the heavy rain. Today after taking it out for another run in the dry i noticed it came on consistently when i got to 4,5k rpm in the upper gears.
With this bike being new to me and not knowing its history i am concerned by this.
I have looked around the forum to try and see what that lamp is and when looking at dutter's post about his volt meter i see that it is white on his bike and has headlight written on it.
Any help and advice would be much appreciated.
shaunmc is offline
post #2 of 17 (permalink) Old 06-11-2009, 07:05 PM
BMan23777's Avatar
The bottom right light on my 89 is white and says headlight.The only red one is bottom center and it's the low oil pressure light.
Brian Manchester
'89 "GRIMM"
04 durango AWD
BMan23777 is offline
post #3 of 17 (permalink) Old 06-11-2009, 08:15 PM
750Doug's Avatar
Originally Posted by shaunmc View Post
Hi all
Red w/Japanese writing??
Can you take and post a picture of your warning light cluster?
750Doug is offline
post #4 of 17 (permalink) Old 06-11-2009, 10:49 PM
Love My Baby
rubyrick's Avatar
Where are you located, Shaunmc? That might be useful info. But it sounds like the PO may have made some changes to the cluster. If it is your oil pressure indicator, please don't ride your bike until you fix what, if anything, is wrong - you could seriously damage your engine.
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
post #5 of 17 (permalink) Old 06-12-2009, 04:23 AM Thread Starter
Pics hope this helps
Instrument panel
And Bike
Hope this helps
shaunmc is offline
post #6 of 17 (permalink) Old 06-12-2009, 08:06 AM
Hmm, you don't have the headlight indicator. It will light up if low or high beam burns out, at which time the working filiment will take over.
Interesting paint job! Don't think I've seen gold wheels yet. Looks good with the purple color.
post #7 of 17 (permalink) Old 06-12-2009, 09:10 AM
flitecontrol's Avatar
Start the bike and see if you have both high and low beam. If not, I'd assume that light is the headlight indicator light. Maybe that's what it says in Japanese?
Was the PO a LSU fan (purple and gold)?
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #8 of 17 (permalink) Old 06-12-2009, 09:31 AM
waggy1236's Avatar
Red is usually the most serious indicator. I would verify oil level,, and quality before prolonged use at high speed. I hope it is just electrical, but I would take it seriously, untill proven otherwise. Strange that it comes only at higher rpm.
57 years experience,Zero accidents. Starting with 1947 Indian Chief. Now VN750 , V65 Magna, Burgman scooter.
waggy1236 is offline
post #9 of 17 (permalink) Old 06-12-2009, 05:36 PM Thread Starter
Thanks for all the replys BUT i think i might have made some progress with with problem. After searching the www for quite some time i have found a few vz750 bikes on various countries auction sites with the same panel as mine. like this one in new Zealand
Then i started searching for vz750 owners manuals but have had no joy there but i did find this russian post that talks about a safe speed lamp indicator.
This is pure «Japanese», and so the speedometer marked up to 180 km / h, and the «priborke» there is a lamp indicator exceeding a safe speed (80 km / h). The maximum speed on the speedometer to just over 175 km / h, then worked limiter . Но такие ритмы движения не для VX750. But such is not the rhythms of motion for VX750. Из-за прямой посадки водителя уже на скорости 145 км/ч за рулем не совсем комфортно. Because of the direct drivers of landing at the speed of 145 km / h at the wheel is not quite comfortable. О том, что этот аппарат не предназначен для скоростных променадов, говорят и тормоза. The fact that this unit is not designed for high-speed promenade, they say, and brakes. Если работа передних двухдисковых не вызывает нареканий, то с задним барабанным дела обстоят совсем по-другому – слабоват! If Dual front, satisfactory, the rear drum things are quite different - слабоват! Зато мотор употребляет бензин любого качества: как хороший АИ 95, так и низкосортный 92-ой. But the engine is using gasoline of any quality: how good the AI 95, and low-grade 92nd. И при этом радует отменной экономичностью – 6,2 литра на «сотню». And while pleased with excellent economy - at 6.2 liters «hundred».
Есть мнение, что долгое жизнепрепровождение с машиной оказывает влияние на владельца. It is felt that a long zhiznepreprovozhdenie machine has an impact on the owner. Соглашусь с этим утверждением, потому как за эти годы совместной жизни стал настоящим фанатом «американской серии» Kawasaki. Agree with this statement, because during these years of marriage has become a real fan of «American Series» Kawasaki. Пока мотоцикл меня полностью удовлетворяет своими возможностями, но не исключаю возможности, что скоро поменяю его на что-то более современное. So far, the bike I was completely satisfied by their abilities, but do not exclude the possibility that soon changed it to something more modern. Например, на VN1500. For example, the VN1500. Ведь все это плоды одной яблони! In fact, all fruits of one apple!
Sorry that this is getting a little long winded but i was worried my bike might be terminal.
Do you think that this is what the light is ?
Thanks in advance
shaunmc is offline
post #10 of 17 (permalink) Old 06-12-2009, 05:37 PM Thread Starter
This is the link to the russian page that i can now post as i have 5 posts
http://translate.google.co.uk/transl...N%26start%3D50
shaunmc is offline
