Top speed - Page 7 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 2Likes
post #61 of 72 (permalink) Old 12-27-2015, 11:46 AM
Yup,9500rpm in fifth
post #62 of 72 (permalink) Old 12-27-2015, 12:05 PM
Originally Posted by vnnikolouzo View Post
9500 in fifth? Couldn't get 8200-8300 in fifth before i made the engine bigger,maybe on a big, very big downhill would go 8600rpm.
If you couldn't pull over 8300 rpms, there's something wrong with your bike. My guess would be jetting.
post #63 of 72 (permalink) Old 12-27-2015, 02:32 PM
vnnikolouzo's Avatar
it went over 8700 in fourth lack of power to go that high in fifth,jets were 146 with K/N and screws 2.5 turns,this was when motor was stock
vnnikolouzo is offline
post #64 of 72 (permalink) Old 12-27-2015, 02:46 PM
K&N Pods,degoat with Harley screaming eagle mufflers,140/40 on the jetting, 2 shims under needle,2.5 turns on mixture screw.for a stock motor it runs good.no flat spots and revs to the moon
post #65 of 72 (permalink) Old 12-28-2015, 08:19 AM
Maybe you weigh 600 lbs?
My completely stock 2002 Vulan 750 with 40 pounds of luggage, my wife behind me and pushing a Plexistar 2 windscreen had no trouble hitting redline, and sometime before that occoured ....it showed an indicated 112 mph (which was likely an actual 101mph)
Was there a 50mph headwind when you tried it? Your jets sound too big btw.
Again, mine was bone stock, so am guessing your fiddling with it is the issue..
post #66 of 72 (permalink) Old 12-28-2015, 10:22 AM
Bone stock they're at 132 so maybe a little rich?
post #67 of 72 (permalink) Old 05-11-2019, 11:21 PM
Jason Pittenger's Avatar
WHAT?!? Do people normally run this engine past redline? And how'd you get that in 5th?
My last attempt showed 105-110 on the speedometer and 117.9 on GPS. This was with 110/90 front, stock rear. 40/143 jets and 1 shim. Ear Shave and open exhaust after GB. My GPS has matched my speedometer at 60 and 80 mph. Not sure why it was off at top speed.
It didn't feel like it had much left in her, and I didn't feel like I had much left in me.
I have since removed the shim and it cruises better. But I haven't been able to try it since that change.
As a side note, my GPS once registered 480,378,410.6 MPH.....so if anyone is curious what the Vulcan will do....😂
'89 Vulcan 750 Bought 4/12/18 @ 17805.9 miles $800
Purchased stock. Wrecked once
22490.0+ miles
Completed modifications:
Removed mufflers, straight pipes out of GB
110/90 Front Tire
Pick-up coil re-gapped to .020"
Compufire 55402 r/r series regulator
USB Outlet + Voltmeter
Repainted Metallic Blue w/ new tank bages
Ear Shave (wo/ coasters) 40/140 NO shims 45MPG
MCCT conversion
Planned modifications:
Custom LED turn signals
Highway Pegs
(Possible) ignition advance
Jason Pittenger is offline
post #68 of 72 (permalink) Old 05-15-2019, 01:32 PM
Originally Posted by msh1156 View Post
I guess I'm either a wuss or an old fart, but why do you need to go that fast?
I'm personally not in that big a hurry and have nothing to prove.
You don't have to be a wuss or an old fart. I'm not even 40 yet and have decided i'm in no hurry, or in any need to impress anyone. Should i want to go fast, i'd like to be able to, but generally speaking, i'm totally content cruising at 55mph on a country road to nowhere.
T-Bone likes this.
1995 VN750
Ear Shave Mod
2-Wire Mod
Blue Wire Mod
RLU Bypass
SH847 R/R
Degoat
V&H Pipes
TheJabberWoggy is offline
post #69 of 72 (permalink) Old 05-16-2019, 03:29 AM
Some times ya feel like a nut...
...Sometimes ya don't
Sent from my A502DL using Tapatalk
post #70 of 72 (permalink) Old 05-16-2019, 03:13 PM
T-Bone's Avatar
I put 110 on the front (rear doesn't matter) and checked with my GPS. It's now dead on balls accurate. (That's an industry term).
T-Bone is offline
