Nitrogen in the tires? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 18 (permalink) Old 06-11-2009, 11:09 AM Thread Starter
VN750_DawgsFan's Avatar
Anyone know if nitro in our tire might help at all or if we can even do it? I know some people get it in their tires on their "cages" because it has less moisture than compressed air which in turn helps to keep the tire from expanding quite so much once the tires heat up and also gives a more accurate tire pressure.
Anyone ever tried this with bike tires or is Ride On sufficient enough?
My daily ride
Metzler ME880s
NGK caps, wires and Iridiums
Coasters (made by Lance328), earshave and rejet with screws turned out 3 turns
Volt gauge w/ custom mounting cup by Lance328 wired into headlight bucket 13.5v-14v
National Cycles Plexistar 2 windshield
DEKA battery
Mutazu GA Black hard bags w/ custom support brackets and relocation brackets made by Lance328
Custom lowers made by Lance328
Vance&Hines Cruzer exhaust pipes
H.I.D. Conversion kit
VN750_DawgsFan is offline
post #2 of 18 (permalink) Old 06-11-2009, 11:28 AM
flitecontrol's Avatar
Ride On is supposed to minimize air leaks. Not sure of any other benefits beside sealing punctures though. I'm wondering if the nitrogen is worth the money. If tire pressure is monitored regularly, as it should be, would seem the need for nitrogen would be moot. JMO
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #3 of 18 (permalink) Old 06-11-2009, 11:43 AM
waggy1236's Avatar
Ride-on looks like good product. But, nitrogen, I found for each pro there were three cons= My opinion, don't waste your money on nitrogen.
57 years experience,Zero accidents. Starting with 1947 Indian Chief. Now VN750 , V65 Magna, Burgman scooter.
waggy1236 is offline
post #4 of 18 (permalink) Old 06-11-2009, 11:49 AM
HAWK
Ccspinner's Avatar
I put Nitrogen in my tires at work (It is free for me) I did not notice any handiling improvement, it is just air. It is suposto help from expanding when getting hot and loss of air over time.
Personally I would not do it if I had to pay for it but we have it at the dealership so I did it.
It can't hurt.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #5 of 18 (permalink) Old 06-11-2009, 11:52 AM
If it were free or the same cost as regular air then I would jump on it. But it can't beat the free air machine at my local gas station.
Also, remember that our atmosphere is already 78% nitrogen to begin with. Is it worth the $10 a tire for an extra 22%?
Harvey_birdman is offline
post #6 of 18 (permalink) Old 06-11-2009, 11:59 AM
Straight roads are evil
Pure nitrogen is heavier and denser than air. Scuba divers sometimes fill their drysuits with nitrogen; being denser than air it's a better insulator.
However, we aren't diving. Since nitrogen is denser, it makes the wheels heavier, giving the bike slightly less performance.
Cons of filling tires with nitrogen:
Cost.
Heavier wheels.
Performance penalty.
Pros:
I wouldn't bother, it's up to you though.
2006 VN750 (SOLD)
63160 miles
Mustang seat
Red spark plug wires
Stainless Steel brake lines
Stiffer fork springs
Givi bags, Wingrack mount
GPS Mount
Pashnit sticker!
EQPlayer is offline
post #7 of 18 (permalink) Old 06-11-2009, 01:25 PM
93VN750's Avatar
Local dealer was having free nitro fills one Saturday so we all got it done. Notice no difference. Gives me another excuse not to check the actual tire pressure which is a bad thing.
Would never pay for it.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #8 of 18 (permalink) Old 06-11-2009, 01:44 PM
Love My Baby
rubyrick's Avatar
Cost.
Heavier wheels.
Pros:
You are only partially correct in stating that nitrogen is denser than air. Air is made up of about 80% ntrogen and about 21% air. Nitrogen molecules are larger (denser) than oxygen, and they do not diffuse well through the rubber in your tires, so substituting pure nitrogen for air helps keep your tire pressure from getting lower over time. This will actually improve handling and provide better performance.
Pure nitrogen is not heavier or denser than compressed air because compressed air contains water vapor which is much heavier and denser than nitrogen, oxygen or the other trace elements in air such as carbon dioxide. Pure nitrogen contains no oxygen to oxidize (rust out) your rims and ruin your tires from the inside.
is it worth the price, probably not. Not to mention the difficulty in adding some nitrogen later on if your tires do loose some pressure. (Every time you check your tire pressure you loose a bit of pressure in the tire). You can't pull into a gas station and fill up with nitrogen, and you can't pump up your tire with nitrogen at home.
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
post #9 of 18 (permalink) Old 06-11-2009, 05:07 PM
I fill my tires with Xeon and Krypton. They don't do anything better than plain air, but they sound cool.
If you buy a tank of Nitrogen you can fill your tires at home. The real problem here is even if you let all the air out of your tire and then fill it with nitrogen, it still won't be 100 percent Nitrogen as there will be residual air left in the tire.
You would have to purge the tire several times in hopes of removing all oxygen and water vapor before you saw any benifits of using the nitrogen.
I do not think that a tire filled with pure nitrogen would weigh significantly more than one filled with air, so citing "Added weight" as a con is silly.
Bottom line is if you can get it for free, it ain't going to hurt. But if you pay for it , you are just wasting your money.
Nitrogen does not seal punctures, Ride On does. They are two different things..but it does bring up the question if Ride On in a tire that is filled with nitrogen acts exactly the same as it does in one filled with regular air. ?
post #10 of 18 (permalink) Old 06-11-2009, 05:41 PM Thread Starter
Just a thought. Figure I'll just go with the Ride On since it does seal punctures, helps balance the tires, helps keep the tires cooler and helps slow down the natural loss of air pressure.
About the only thing Nitro would be good for is help get the tires cooler and more accurate pressure than air.
My daily ride
Metzler ME880s
DEKA battery
