Speedometer failure - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 06-08-2009, 11:11 AM Thread Starter
Speedometer failure
This morning my speedometer just quit working. Before I do anything, I just wanted to check with you guys to see if you think it's probably just a bad cable. Thanks
lbcole0915 is offline
post #2 of 8 (permalink) Old 06-08-2009, 11:36 AM
ya, most likely the cable. check the connections on the two ends, sometimes the square ends will break
dutter is offline
post #3 of 8 (permalink) Old 06-08-2009, 01:17 PM
D2u
D2u
D2u's Avatar
Had the speedo needle been bouncing? If so It should have been lubed and is most likely broken.
1992 VN750 22,350 miles 18,700 when I bought it last year 04/17/2008
Streetshield EX
degoat
drilled mufflers
Capped (soon to be coaster)
Custom Grips
Wide blade levers
Throw over leather saddlebags
Deka MF AGM ETX15L
NGK Iridums
DIY Brackets,and highway pegs
To do list.
custom seat
teardrop mirrors
DIY Floor boards
D2u is offline
post #4 of 8 (permalink) Old 06-08-2009, 01:45 PM
fergy's Avatar
Probably one of the most overlooked and maybe the easiest maintenance item to do on our bikes! Lubing the speedo cable.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #5 of 8 (permalink) Old 06-08-2009, 01:52 PM
ferg, now i got go check mine tonight.
dutter is offline
post #6 of 8 (permalink) Old 06-08-2009, 03:13 PM
Yes, and remember to use grease, not your normal cable lube. You can pull the cable out of the housing to clean and lube it. I use marine grade wheel bearing grease (a bit more waterproof than regular grease) Be carefull you do not lose the tiny little "washers" that fit on the cable ends.
(The reason you use grease is because this cable spins..instead of just moving back and forth)
They can break from time to time, so taking them completely off the bike will tell you if it's the cable or if your speedo or drive unit blew up.
post #7 of 8 (permalink) Old 06-08-2009, 03:42 PM
fergy's Avatar
X2 on the grease! Thanks for completing that one.
Fergy
2002 VN1500 Classic
SEAFOAM JUNKIE!
fergy is offline
post #8 of 8 (permalink) Old 06-20-2009, 05:03 PM
Broke my cable not 15 minutes ago.
Its funny the things you read up on and learn about after something has already broken. Bought a new one just a second ago.
Punday is offline
