couple quick questions - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 06-07-2009, 02:31 AM Thread Starter
ok first off, what is the most recommended MF-AGM battery?
most recommended voltage meter
and if your bike no longer has the goats belly, (mine has jardine pipes i believe) would the R/R still be recommended to be relocated? i pretty much never drive at low speeds (i.e. parade speeds as once mentioned)
and also kinda dumb question, what is the socket size needed for the spark plugs on this bike? none of my spark plug sockets fit it, and haven't had a chance to bring home any sockets from work to try
that is all for now
thanks in advance!
85vulcan is offline
post #2 of 5 (permalink) Old 06-07-2009, 02:54 AM
The Professor
lance328's Avatar
Get a Deka or Big Crank battery, they are made by she same company.
Battery
http://cgi.ebay.com/ebaymotors/Deka-...ehicleQ5fParts
Use a 2" marine voltmeter with an Autometer 2203 mounting cup or the Kuryakyn led voltmeter.
If the exhaust crosses under the R/R I would relocate it.
18mm for the plugs.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 5 (permalink) Old 06-07-2009, 06:57 AM
Love My Baby
rubyrick's Avatar
Good one Lance. Quick response, to the point. All good.
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
post #4 of 5 (permalink) Old 06-07-2009, 08:07 AM
The above sounds good to me... However I did get the YUASA battery YTX14AHL-BS from me local Kaw. dealer as my old battery had gone south after my lil spill... It was $80... Which I think is not bad, considering if something is or does go amiss I can return it locally and not have to mess with shipping it back to someone somewhere, and hastle with them by phone or internet, and I do try to support my local dealer when I can as he does me pretty good on prices & support...
post #5 of 5 (permalink) Old 06-07-2009, 03:02 PM Thread Starter
thanks a ton for the response. ill have to take a gander at my exhaust situation, i may just relocate it anyways just for sheer peace of mind. and ill be sure to pull the connections apart, clean em real good with contact cleaner and put die electric grease in the connection.
85vulcan is offline
