Lousey Gas Milage... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 31 (permalink) Old 05-29-2009, 09:28 PM Thread Starter
Big Dumb Viking
asbrand's Avatar
Send a message via AIM to asbrand Send a message via MSN to asbrand Send a message via Yahoo to asbrand
Tonight, I got on the bike for the first time in 2 weeks (nothing but rain around here, today is first day of good weather).
Tripometer had 60 miles on it since last fill-up. Gas gauge doesn't work.
I got a lousey 2 miles down the road...and was running out of gas. Flipped the thing over to the reserve tank, got about another 1/2 mile...and the engine died. Pulled over, put on the choke, pumped the hell outta the throttle, and after about 3 minutes, finally fired it back up again.
Is it normal for it to take so long to re-route from the reserve tank?
And...is it normal to only get a little over 60 miles on a full tank?
Could be because I'm keeping up with traffic on the interstate AND I'm a big guy (310#).
What say ye?
-Az
http://www.asbrand.com
1989 Kawasaki Vulcan 750
Upgrades so Far:
Analog Voltmeter
PFIII Windshield
RAM GPS Mount w/Garmin GPS
Cigarette Lighter Power Adapter
Saddlemen's Classic Explorer Seat
Pro-Tac Driver's Backrest
LED Tail Light
LED Rear Turn Signals
Luggage Rack
Storage Trunk
Engine Guard w/Highway Pegs
Radiator Grill Cover
Turn Signal Relocation Bracket
Saddlebags
Floorboards
asbrand is offline
post #2 of 31 (permalink) Old 05-29-2009, 09:41 PM
Concert connoisseur
wib714's Avatar
I've only used reserve once but it only took about 20 seconds to kick in. as for 60 miles on a tank I think I would be looking for leaks. should get about 130-150 maybe a little less with your size.
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #3 of 31 (permalink) Old 05-29-2009, 09:55 PM
The Professor
lance328's Avatar
Are you getting that mileage with or without reserve?
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #4 of 31 (permalink) Old 05-29-2009, 10:23 PM
Are you absolutely sure ya only did 60 miles since the last fill-up?
How many gallons did it take to fill it up again?
Also, the carbs are vacuum operated. Twisting the throttle doesn't pump gas into them until the engine is turning over.
post #5 of 31 (permalink) Old 05-29-2009, 10:52 PM Thread Starter
Big Dumb Viking
asbrand's Avatar
That is 60 miles BEFORE the reserve.
And, yes, I am absolutely certain. I always reset the tripometer when I fill up.
I don't see or smell any leaks.
Hmmm...
-Az
Upgrades so Far:
Analog Voltmeter
PFIII Windshield
LED Tail Light
Luggage Rack
Storage Trunk
Saddlebags
Floorboards
asbrand is offline
post #6 of 31 (permalink) Old 05-30-2009, 12:01 AM
I am 290 pounds or better,and running 150 main jets,ear shave with K&N filters and a scootworks exhaust bypass with stock mufflers with 4 -3/8 " holes drilled in each,An crank it out pretty regularly and I get about 120 to130 before going on reserve,And I think this is kinda low for what these other guys are getting,Something ain't right if yours is stock
post #7 of 31 (permalink) Old 05-30-2009, 12:04 AM
Love My Baby
rubyrick's Avatar
You may have a disconnected vacuum hose or a your fuel tap (petcock) may need service. Turning to reserve should kick in right away.
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
post #8 of 31 (permalink) Old 05-30-2009, 12:04 AM Thread Starter
Big Dumb Viking
asbrand's Avatar
What was weird, after I swapped over to reserve, and the engine still died, I had to pull over. Before I got it cranked up again, I opened the tank, and there seemed to be about 1/3 or more of a tank left. I could swish it around.
Could there be something blocking the gas flow when it gets to about 1/3 of a tank, on the regular setting, but gets bypassed when I switch to reserve?
Very bizarre.
-Az
Upgrades so Far:
Analog Voltmeter
PFIII Windshield
LED Tail Light
Luggage Rack
Storage Trunk
Saddlebags
Floorboards
asbrand is offline
post #9 of 31 (permalink) Old 05-30-2009, 12:14 AM
The Professor
lance328's Avatar
Very bizarre.
Basicaly once you hit 1/3 you are at reserve.
The pickup is at a lower level for reserve.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #10 of 31 (permalink) Old 05-30-2009, 12:22 AM
On His Lady Vulcan
wkrizan's Avatar
Or hes finally experianced the "Phantom outta gas problem" that allot of us already have...??????
Pictures of the "Ladies"
wkrizan is offline
