The Journey Ending.............. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 24 (permalink) Old 05-20-2009, 11:00 PM Thread Starter
The Reanimater
jthill524's Avatar
Location: A Little Town Along I-5 in Northern California
Well The Engine is put back together and ready to go back
in the Frame
Hope I got the carbs put on right.
Next time I put up pictures they should be of the engine in the Frame
___________________________
The journey begins:
https://www.vn750.com/forum/showthread.php?t=10466
The journey continues:
https://www.vn750.com/forum/showthread.php?t=10664
__________________
HomeMade Clutch Basket Holder - Kawasaki Vulcan 750 Forum
https://www.vn750.com/forum/showthread.php?t=10756
Bleeding Hydraulic Adjuster - Tech Tip
https://www.vn750.com/forum/showthread.php?t=10887
JaY
"Veronica"
2002 VN750 Vulcan
Rebuilt Engine
ACCTs lubed w/TOC Springs
Pick-up Coils Gapped at .018"
Splines Lubed
Deka MF AGM EXT15L Battery
NGK Iridium IX Spark Plugs
R/R Relocation Fix
New Rear Rack
Stock Seat Repadded
Ext-BackRest
jthill524 is offline
post #2 of 24 (permalink) Old 05-21-2009, 05:10 AM
750Doug's Avatar
Nice job.
750Doug is offline
post #3 of 24 (permalink) Old 05-21-2009, 08:13 AM
skalding's Avatar
Looks awesome. Journey's just beginning, I think.
Scheherazade
'86 VN750
MF Battery, Iridium Plugs, RR relocated, Voltmeter, 170/80/15 Kenda Kruz rear tire, DIY Samsonite hard bags, DIY shaved seat with Beaded seat pad ('cause that's how I roll) and the dreaded STATOR CHANGE.
Shining Black Bess '86 VN750, retired for parts after a fried stator and being knocked (kee-runch) in her parking spot.
skalding is offline
post #4 of 24 (permalink) Old 05-21-2009, 11:23 AM
flitecontrol's Avatar
Looks good. Hope you go many miles before needing to repeat any part of this journey!
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #5 of 24 (permalink) Old 05-21-2009, 09:58 PM
IronMan750's Avatar
Looks like you got 'er goin in the right direction. My stator is shorted to ground so it looks like I'll have to pull mine also. How difficult is yank'n that badboy? I'm very mechanical but I've never pulled a street bike engine and this engine looks tighter than a....well, it looks tight. I just want an idea so I'll be able to plan this job a little better. I'll probably take care of some other stuff as long as it's out.
No way this could happen in the Winter when I can't ride it anyway....NooOOo!
2003
*Battery connected at both ends!
*Real air in the tires
*New Registration sticker
*Seat wiped off
*Low AND Hi beam headlight!
*New #1157 tail light bulb
*Brake pedal still on the right
*Custom valve stem caps made from black plastic!
*Custom built ignition key from Kawasaki
Does anybody really care?
"When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car"
IronMan750 is offline
post #6 of 24 (permalink) Old 05-22-2009, 02:03 AM Thread Starter
The Reanimater
jthill524's Avatar
Well The Engine is back in and ready for everything to be rehooked
Inch By Inch, Piece By Piece.........
JaY
"Veronica"
2002 VN750 Vulcan
Rebuilt Engine
Splines Lubed
R/R Relocation Fix
New Rear Rack
Stock Seat Repadded
Ext-BackRest
post #7 of 24 (permalink) Old 05-22-2009, 06:25 AM
More than I would tackle... However I will say, good luck when you hit the starter button......
post #8 of 24 (permalink) Old 05-22-2009, 02:05 PM
Fire Ant's Avatar
Thanks for all of the pics you've posted along the way here. I've enjoyed following they odyssey. Best of luck when you press the starter button...
--FA
K.J. "Fire Ant" Lord
VROC #28807
Decatur, TX
'03 VN750 "Serenity"
Rear Turn Signal Relocation
Front Brake Replacement
Spline lube, per Fergy's excellent instructions (that he has posted around here somewhere)
Kevlar Clutch Plates
Metzeler ME880 Tires
Stebel Nautilus Air Horn
ACCTs Rebuilt
Saddlemen Explorer Seat
MCCTs Installed
Kuryakyn Wide Levers Installed
Fire Ant is offline
post #9 of 24 (permalink) Old 05-27-2009, 10:14 PM Thread Starter
The Reanimater
jthill524's Avatar
I would like to give Big Thank You to Chiron for His Used Exhaust System.
Also one to Festus for the Left-hand threaded bolt that got my engine together
and the big box of parts thats on it's way to help finish this project.
There is more people I would like to thank and will at the end of this thread.
JaY
"Veronica"
2002 VN750 Vulcan
Rebuilt Engine
Splines Lubed
R/R Relocation Fix
New Rear Rack
Stock Seat Repadded
Ext-BackRest
post #10 of 24 (permalink) Old 06-08-2009, 12:37 AM Thread Starter
The Reanimater
jthill524's Avatar
Well I guess it won't be ending anytime soon..........I've gotten 3 Pops (Nice Blue flames through the Ears) But can't get it to start. I don't think the plugs are firing all the time.
So I have a MF battery on it's way to see if that makes a differance. I also run across another set of Coils and another R/R.
I knew it wasn't going to be as easy as just Rebuilding the Engine.
JaY
"Veronica"
2002 VN750 Vulcan
Rebuilt Engine
Splines Lubed
R/R Relocation Fix
New Rear Rack
Stock Seat Repadded
Ext-BackRest
