Mods from this weekend and results! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 05-18-2009, 10:42 PM Thread Starter
dirtrack650's Avatar
Had some time to get the bike ready for commuting and weekend rides with my Bro. Here are some of the things I did that worked well for me...
  1. Used 'tire black gel' on black plastic to make it black again. Worked great.
  2. Cut down 8mm plug wire to fit into coil tower. Plug ran cleaner.
  3. Wrapped rear header with header wrap. Looks good, but feels hotter.
  4. Re-jetted to 140 mains, 40 pilot. Should have went to 142 or 144
  5. You can see my cheap-o bag mounts in the pict (T hardware) works great and supports the glass packs.
  6. SHINKO rear tire 150/90 great choice for a budget tire. Dropped RPM by 400 @ 70 MPH.
  7. Turn signal relocate to license plate mount.
Future mods will include igloo saddle bags, paint gold wing front fender to match tank colors, and more, much more LED lighting.
Not bad for a salvage bike.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #2 of 9 (permalink) Old 05-18-2009, 10:48 PM
what do those pipes sound like and do I see the goat peeking out there from the side?
post #3 of 9 (permalink) Old 05-18-2009, 10:50 PM
phurp's Avatar
Good work. I was washing my bike today after an all day rain ride yesterday and was thinking of the same idea for the black plastic. what brand gel was it? I have some spray stuff i was going to try. did you do the tand shroud and radiator shroud? those glass packs look mean!!
1990 vn-750
metzler 880's
r/r relocated
iridium plugs
ngk plug caps
mf agm battery
ballancer and stator replaced. (Lance328)
Pro Tac Backrest
progressive fork springs
fork seals replaced
2003 kdx 220
frp chain gude
frp skid plate
acerbix hand guards
uni filter
phurp is offline
post #4 of 9 (permalink) Old 05-18-2009, 10:56 PM
I like that look too I was wondering how loud it is because I have the bypass kit in place of the GB
post #5 of 9 (permalink) Old 05-18-2009, 10:57 PM Thread Starter
Pipes sound good. Had them around the shop so I pulled the original tips, drilled the goat 100% (it's more of a balance tube than anything else) and fitted the glass packs. I did this mod to extend the end of the pipes to the rear of the bike for noise comfort on long trips. Cost $0. Sound and comfort? worth every penny of time spent doing the project.
What I want is a 2 into 1 with a stainless glass pack but at today's prices, it's going to be a while.
Take care,
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Emgo air filters
Tank bag-Eclipse
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Rotella T6
post #6 of 9 (permalink) Old 05-19-2009, 11:59 PM Thread Starter
Thanks,
Brand was BLACK MAGIC 'Tire Black Gel'. Used it on the radiator grill and the plastic in front of the tank. Gave the plastic a dark black gloss.
The glass packs are painted with Hamerite black - more like a dark grey - wrinkle finish.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Emgo air filters
Tank bag-Eclipse
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Rotella T6
post #7 of 9 (permalink) Old 05-20-2009, 09:07 AM
skalding's Avatar
This is going to be sweet with the bags.
I was going to ask you about the black plastic restoration you used, but someone beat me to it.
I did want to ask about the bar ends though - what do you use and do they make a noticeable difference?
Scheherazade
'86 VN750
MF Battery, Iridium Plugs, RR relocated, Voltmeter, 170/80/15 Kenda Kruz rear tire, DIY Samsonite hard bags, DIY shaved seat with Beaded seat pad ('cause that's how I roll) and the dreaded STATOR CHANGE.
Shining Black Bess '86 VN750, retired for parts after a fried stator and being knocked (kee-runch) in her parking spot.
skalding is offline
post #8 of 9 (permalink) Old 05-21-2009, 05:50 PM Thread Starter
Bar Ends helped to take the vibes out of the 10" pull backs on my bike and I like the style. Here's something similar on eBay, I got my ends at a local shop.
http://cgi.ebay.com/ebaymotors/BEA-R...Q5fAccessories
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Emgo air filters
Tank bag-Eclipse
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Rotella T6
post #9 of 9 (permalink) Old 05-26-2009, 01:05 AM
Jace Bror's Avatar
how much of a sound difference did it make having the ends of the pipes further back? I have some HD dynas to put on, and they would go back that far or further if I left the goat on. I have noticed the sound difference on bike after drilling out the baffles on the stock pipes, especially with my helmet on.
Sold 750 (9-09)
Mustand Seat (6-09)
Balanced Carbs (4-09)
Adjusted Mix Screws (4-09)
R/R Relocated (3-09)
Splines Lubed (3-09)
Painted flat blak (3-09)
Kuri grips (8-08)
Kuri Longhorn pegs (8-08)
Iridium Plugs (8-08)
Highway bar/ engine guard(FS)
Facebook ID Eli Gaffke
Jace Bror is offline
