Questions about Stator Replacement; additional parts needed and prevention - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 26 (permalink) Old 05-08-2009, 09:11 AM Thread Starter
Hey guys, I'm leaning towards biting the bullet on this one, I just like the bike too much.
I'm going to have a shop do it - does anyone know if any other parts are needed for this job besides the stator? Much cheaper if I can get them myself.
Also - is there anything that can be done to help prevent this from happening again? Should I buy a new r/r and just throw it on to be safe, or any other alterations while the mechanic is already digging around in there?
Thanks a bunch
apoklyptk is offline
post #2 of 26 (permalink) Old 05-08-2009, 10:58 AM
On His Lady Vulcan
wkrizan's Avatar
You will need the stator houseing gasket, the O-ring gasket for the cover that has the 3 screws and the gasket for the bevel gear case. It wouldnt hurt to also replace the R/R but if your strapped for cash and its still good, well its up to you. The best preventivative maintenance is regular oil changes and make sure you dont run low on oil. Theres been a few write ups on others direct fuesing the stator but I think the jury is still out on if that helps or not.
Peace
Pictures of the "Ladies"
wkrizan is offline
post #3 of 26 (permalink) Old 05-08-2009, 11:37 AM
Simple Solutions
seebeeare's Avatar
x2 on oil changes ect ... i wouldnt change the rr unless ots needed
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
How To Test the Stator
seebeeare is offline
post #4 of 26 (permalink) Old 05-08-2009, 03:25 PM
This is what I got when I had a dealer replace mine...
GASKET,GEAR CASE (ended up not needing this one)
GASKET,GENERATOR COVER
O-RING
GASKET KIT, EXHAUST (went with the Harley ones)
STATOR
OIL
ANTIFREEZE
Also was suguessted I get the 3 little O-rings for the cover and maybe even the 3 bolts, but I didn't. That was cheap enough for the dealer to supply.
Mine ending up costing $308 in labor, at the dealer.
post #5 of 26 (permalink) Old 05-08-2009, 03:38 PM Thread Starter
Thanks so much for the help guys. I went to try to buy these parts but... nothing is ever easy...
http://www.actionkawasakiparts.com/p.../Kawasaki.aspx
I cannot find any of these gaskets in the fiche.... can anyone suggest a link or a better way to narrow down the search for these gaskets needed?
post #6 of 26 (permalink) Old 05-08-2009, 04:29 PM
Not sure what you're asking, but here's a link to the left side engine cover with #'s.....
Clickity Click here
Might be cheaper to go with Ron Ayers or Bike Bandit, rather than Kawasaki.
post #7 of 26 (permalink) Old 05-08-2009, 04:30 PM
Simple Solutions
seebeeare's Avatar
http://partsfinder.onlinemicrofiche....=13&A=475&B=19
http://partsfinder.onlinemicrofiche....=13&A=475&B=24
1 11060-1089 GASKET,GENERATOR COVE $10.64 $10.64
3 92055-049 "0" RING,31MM $1.48 $4.44
1 92055-1319 RING-O $7.29 $7.29
1 11060-1086 GASKET,GEAR CASE $7.12 $7.12
Those are all from cheap cycle parts i got away with just the ones in bold
and for a stator ricks is comming up as the one mostly suggested and the one i got is : http://www.electrosport.com/street/s...reet_51050.php
The only things missin is oil and antifreese
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
post #8 of 26 (permalink) Old 05-08-2009, 04:37 PM Thread Starter
awesome, thanks a bunch guys - this is the stator I bought - I read on here the electrosport one goes bad?
http://www.ricksmotorsportelectrics.com/results.php
post #9 of 26 (permalink) Old 05-08-2009, 04:38 PM
Simple Solutions
seebeeare's Avatar
missin the exhastgaskets too the ones that go betwen the pipe and goat ... assuming u have stock exhast the part number is :
4 11009-1666 GASKET,EXHAUST PIPE C $11.11 $44.44
If your carful and keep the goat connected in all directions u can probably get away without them or just 2 for between the pipe and the goat... the last time i did this i removed the goat with everythin attached eliminating the need to replace these gaskets... if u deside to degoat while you are at this point i recomend new gaskets on both ends... a big bennifit to the degoat is u can remove the exhast in 2 pieces one on each side...
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
post #10 of 26 (permalink) Old 05-08-2009, 04:40 PM
Simple Solutions
seebeeare's Avatar
i hope mine doesnt go bad but if it does then i'll dig in again...
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
