Questions about Stator Replacement; additional parts needed and prevention - Page 3 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #21 of 26 (permalink) Old 05-08-2009, 11:07 PM
Originally Posted by hyperbuzzin View Post
Mine ending up costing $308 in labor, at the dealer.
Originally Posted by Jace Bror View Post
they charged $308 for parts and labour?
Originally Posted by wib714 View Post
I believe that was just his labor as I read in another thread, otherwise I'd be taking my bike where he went!
Yep, just labor cost. I wish that woulda been for everything, but still I don't think it was too bad.
Also, seebeeare, part# 92055-049 is the oil fill plug O-ring?
I believe you mean part#92055-109, RING-O, 5.28X1.78 (3 pieces needed)
post #22 of 26 (permalink) Old 05-08-2009, 11:21 PM
The Professor
lance328's Avatar
The 31mm o-rings he has listed is for the spark plug tube.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #23 of 26 (permalink) Old 05-08-2009, 11:26 PM
Simple Solutions
seebeeare's Avatar
good catch hyper... sorry apoklyptk my bad
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
How To Test the Stator
seebeeare is offline
post #24 of 26 (permalink) Old 05-09-2009, 02:09 PM
Concert connoisseur
wib714's Avatar
I just priced everything at cheapcycleparts.com too and came up with about 40 bucks but I didnt find the exhaust crush gaskets there. thats about 15 less than bikebandit. I know where I'll be ordering from. do they have the crush gaskets?
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #25 of 26 (permalink) Old 05-09-2009, 04:31 PM
Gasket under 3 screw cover
Hi All,
I just recently replaced my stator and balancer dampers and didn't remove the cover with 3 screws. I see it listed here as needing to be replaced as part of this procedure. Is this necessary? Did I miss a step?
Rick
rhlee is offline
post #26 of 26 (permalink) Old 06-03-2009, 09:18 AM
If you didn't remove that cover then that gasket shouldn't need to be replaced. Keep a sharp eye on your oil level to ensure there aren't any leaks and you should be fine.
Harvey_birdman is offline
