Oil Based Paint? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 05-07-2009, 10:17 AM Thread Starter
Oil Based Paint?
Back when I was a commercial electrician we used to paint our conduit white to match the stores we worked in. We had to use oil based paint because it was the only kind that would adhere to the metal.
So I'm talking to a friend and fellow rider this past Tuesday and I brought up the home paint job I'm looking to do. He said one of our other buddies painted pin stripe flames on his factory black tins with no prep work. He said he used oil based paint, a small thin paint brush and just dipped, painted, and was done. He said he didn't even clear. Does anyone know if this is actually possible?
LibertyPilot is offline
post #2 of 12 (permalink) Old 05-07-2009, 11:29 AM
On His Lady Vulcan
wkrizan's Avatar
Its possible sure, but without shooting clear to protect it, it wont look good for very long.
Pictures of the "Ladies"
wkrizan is offline
post #3 of 12 (permalink) Old 05-07-2009, 02:13 PM
^ X2! ^
Also, without any prepping, even if clearcoated, the stripes might easily come off with little effort (bumping with your leg or something as simple as that)
post #4 of 12 (permalink) Old 05-07-2009, 06:59 PM
Sign paint and lettering paint is oilbase paint I do it on semi's and tractor/trailer rigs all the time without clear coating and it stays for years.
Rebel is offline
post #5 of 12 (permalink) Old 05-07-2009, 07:01 PM
I own Custom Decals and Signs
Rebel is offline
post #6 of 12 (permalink) Old 05-07-2009, 07:35 PM
That should settle that ,huh? straight from the man.
post #7 of 12 (permalink) Old 05-07-2009, 09:20 PM
Agree but I doubt the paint Rebel uses is $2.00 a quart stuff, there are numerous types of "oil" based paints.
Rckmtn
Dennis Huff
Cheyenne, Wy.
05 VN 750
Spitfire windshield
self canx turnsignals
Jardine 2 into 2
Luggage rack
Extended passenger backrest
KURYAKYN LED voltmeter
130 DB horns
rckmtn is offline
post #8 of 12 (permalink) Old 05-08-2009, 08:13 AM Thread Starter
Ok so if I spend 25 to 45 dollars, even 75 on some serious paint, its still less than the 200 bucks others have spent on all the equipment needed to do the job. I could probably even throw in some clear and still be under.
Rebel, can you recommend an oil based paint that would be good for this? Are there any special instuctions I need to know? Can you recommend a proper clear?
post #9 of 12 (permalink) Old 05-08-2009, 08:21 PM
I use Dupont sign paint witch is oil base. The main reason is because it doesn't show brush marks. Wipe the surface with enamel thinner to be sure it's clean
Rebel is offline
post #10 of 12 (permalink) Old 05-08-2009, 08:27 PM
Jace Bror's Avatar
Sign paint is awesome. I "borrowed" half a gallon in white to do some painting on my in-laws house on their wood window planters, that was like 5 years ago and it still looks grrreat.
Sold 750 (9-09)
Mustand Seat (6-09)
Balanced Carbs (4-09)
Adjusted Mix Screws (4-09)
R/R Relocated (3-09)
Splines Lubed (3-09)
Painted flat blak (3-09)
Kuri grips (8-08)
Kuri Longhorn pegs (8-08)
Iridium Plugs (8-08)
Highway bar/ engine guard(FS)
Facebook ID Eli Gaffke
Jace Bror is offline
