HELP!! Bike Won't Start #$^@*~%! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 18 (permalink) Old 05-05-2009, 08:28 PM Thread Starter
Unhappy HELP!! Bike Won't Start #$^@*~%!
HELP!!
The bike ran well for 2 rides. Now it won't start.
I started it up today as usual but it idled very weak and rough. There was a strong smell of gas. Even with the choke on I had to rev the throttle to keep it going. After about 45 seconds it stopped running. I started it again and it idled weakly for about 15 seconds then died again. Now when I press the starter button in cranks over very strongly but won't start.
WTF!? This bike is beginning to wear me down
What and how should I diagnose? Please help before I push it off a cliff!!!!
FlaRider is offline
post #2 of 18 (permalink) Old 05-05-2009, 08:51 PM
On His Lady Vulcan
wkrizan's Avatar
1st. pull your plugs and check for fouling, if wet then replace and clean your carbs. Other suggestions sure to fallow.
Peace
Pictures of the "Ladies"
wkrizan is offline
post #3 of 18 (permalink) Old 05-05-2009, 09:07 PM
Crobins365's Avatar
It does sound like maybe the floats are stuck - the carbs are drowning and sputtering out. By any chance, did you put fuel in *after* your most recent ride? There's so much garbage in the gas anymore that you may have picked up some gunk that's jamming the flow. Try a little Seafoam, and if that doesn't work, I second wkrizan on cleaning the carbs. Again, though, someone else may have a suggestion that doesn't involve pulling the carbs...
C
Crobins365 is offline
post #4 of 18 (permalink) Old 05-05-2009, 09:13 PM
On His Lady Vulcan
wkrizan's Avatar
Damn.... I keep forgetting that not everyone has done an ear shave. I can pull and clean my carbs and have them back on the bike faster now than running to the store for a can of Sea Foam...LOL
wkrizan is offline
post #5 of 18 (permalink) Old 05-05-2009, 09:26 PM
It does sound like maybe the floats are stuck - the carbs are drowning and sputtering out...
Does pecking on these carbs sometimes free a stuck float like it did on our old cages...??? Would that be a cheap try...???
post #6 of 18 (permalink) Old 05-05-2009, 09:33 PM
Crobins365's Avatar
I think some have tried that (pecking). You can also get some carb cleaner (with one of those straws) and shoot it up through the drain plug on each carb - that may be enough to work something loose.
C
post #7 of 18 (permalink) Old 05-05-2009, 10:53 PM
The Professor
lance328's Avatar
I did not know there were cliffs in Florida, did you install the gremlin bell????
As mentioned it could be a stuck float or debris in the float valve or a break down in the ignition system. I will call you on the Bat phone.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #8 of 18 (permalink) Old 05-06-2009, 05:53 AM
750Doug's Avatar
Have a look at posts #3 and #5 on this thread.
Two good ways to clean the carbs without having to pull them. I've used these methods twice since my carb overhaul and it's worked just fine.
750Doug is offline
post #9 of 18 (permalink) Old 05-06-2009, 12:30 PM Thread Starter
Wkrizan, Cindy, Old Dog, Doug, Lance --
Thanx for each of your responses! Lance and I discussed your ideas on the bat phone and I will be trying some of your tips:
* bad gas
* fouled plugs
* stuck float
* use less choke
* vacuum diaphram--check vacuum hoses for fuel
* install Doug's Gremlin Bell!
The dealership cleaned the carbs recently (about 300 miles ago) and the bike has been running very well. So, I'm hoping it's not the carbs!
No, there are no cliffs in Florida . . . but there is a VERY high Skyway bridge not too far from me.
I'll let you all know how it goes.
Many Thanx to all!!
FlaRider is offline
post #10 of 18 (permalink) Old 05-06-2009, 01:04 PM
flitecontrol's Avatar
Been on that sucker many times! Certainly tall enough to do the trick! Take some ramps to get it over the guard rail! Then smile while you watch it faaaaaaaaaaaaalllllllllllllll!
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
