bike stalls out of no where - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 05-03-2009, 10:41 AM Thread Starter
hey everyone maybe you can figure this one out. i just did the ear shave and had the carbs taken off sonic cleaned and had bigger jets put in. i got the bike all back together a few weeks ago have put over 100 miles on it without no problems. yesterday i start it up run down the street and it started to cut out and it stalled. it wouldnt start right off the rip. so i open the tank look in to make sure i got gas and i do. wait a few then i try again fires right up. so i go back home leave it run for 10 minutes figuring it was just something stupid. i go about 3 miles maybe and does it again. i pulloff to the ice cream store and do the same thing. this time i put the tank marker on reserve and left the tank open and it fired up. wtf is going on with this? does that pump where the gas comes out need replaced? thanks again
david
great 1 is offline
post #2 of 8 (permalink) Old 05-03-2009, 10:48 AM
Jace Bror's Avatar
how full of gas are you, completely full, or just a little?
Sold 750 (9-09)
Mustand Seat (6-09)
Balanced Carbs (4-09)
Adjusted Mix Screws (4-09)
R/R Relocated (3-09)
Splines Lubed (3-09)
Painted flat blak (3-09)
Kuri grips (8-08)
Kuri Longhorn pegs (8-08)
Iridium Plugs (8-08)
Highway bar/ engine guard(FS)
Facebook ID Eli Gaffke
Jace Bror is offline
post #3 of 8 (permalink) Old 05-03-2009, 10:52 AM
BMan23777's Avatar
I had the same issue with mine and it was the vent that runs from under the cap and comes out under the seat.It was pluged.Ran some wire through it and then blew it out and it's been goo ever since.
Brian Manchester
'89 "GRIMM"
04 durango AWD
BMan23777 is offline
post #4 of 8 (permalink) Old 05-03-2009, 09:07 PM Thread Starter
i would say about less than a 1/4 . i blew oout that hose form the tank and so far it hasent done it again. thanks again everyone
great 1 is offline
post #5 of 8 (permalink) Old 05-03-2009, 10:40 PM
Simple Solutions
seebeeare's Avatar
that isnt a pump at the bottom of the tank but if i were to guess is u ran out of gas so when u went to reserve it was all good ...
What did u do with the carb vent hose? make sure that one is unobstructed too ...
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
How To Test the Stator
seebeeare is offline
post #6 of 8 (permalink) Old 05-03-2009, 11:51 PM
The Professor
lance328's Avatar
His carb vent hose goes to an Emgo breather and the hose is new. He did an earshave and I gave him the info he needed.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #7 of 8 (permalink) Old 05-05-2009, 08:11 PM Thread Starter
yeah he did a awesome job walking me through it thanks again ron you the man!!!
great 1 is offline
post #8 of 8 (permalink) Old 05-05-2009, 09:54 PM
The Professor
lance328's Avatar
Your Welcome!! As with many others here I help when I can.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
