handlebar brackets bolt covers - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 05-01-2009, 12:26 AM Thread Starter
electrum's Avatar
Question handlebar brackets bolt covers
the previous owner seems to have moved the handlebars way forward from the stock position and i'd like to move them back to their stock position.
the bolts for the brackets have some kind of black covers over them.
do these little covers pop off somehow? are they going to get busted getting them off or can i reuse them?
also, the brake lever is not on the same level as the clutch lever... the clutch is fairly horizontal, but the brake is lower than horizontal.. but if i rotate the brake back to be horizontal, then the mirrors will not match... is this normal? or is the brake lever normally a farther reach? if you can understand me without a picture..
96 Vulcan 750
electrum is offline
post #2 of 3 (permalink) Old 05-01-2009, 03:30 AM
The little black plastic covers will pop out with a kinfe blade or possibly with a good finger nail... They have a center stem that goes into the allen head socket and are reusable... The mirrors should be able to pretty much line up by loosening and retightening the bottom of the stem lock nut after turning the crooked stem to where you want the mirror... At least the looky part of the mirror can be positioned right...
If you can understand my instructions you are doing better than me...lol...
HTH...Have a good one...Old Dog...
post #3 of 3 (permalink) Old 05-01-2009, 08:01 AM
skalding's Avatar
Silicone the caps when you put them back in. Otherwise you can get puddles in there if you're out in the rain.
Scheherazade
'86 VN750
MF Battery, Iridium Plugs, RR relocated, Voltmeter, 170/80/15 Kenda Kruz rear tire, DIY Samsonite hard bags, DIY shaved seat with Beaded seat pad ('cause that's how I roll) and the dreaded STATOR CHANGE.
Shining Black Bess '86 VN750, retired for parts after a fried stator and being knocked (kee-runch) in her parking spot.
skalding is offline
