Ear Shave VS Ear Replacement - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 16 (permalink) Old 04-29-2009, 08:54 PM Thread Starter
Im not really interested in rejetting the carburetors and installing the new parts for the standard ear shave. Has anyone done or thought of just replacing the ears themselves with short cone filters? And just coming up with a way to mount them directly to the airbox that the ears mount to?
dastone07 is offline
post #2 of 16 (permalink) Old 04-29-2009, 11:30 PM
i've never done this before, but i dont see why you couldnt get some small KN cones and hose clamp them onto the ear tubes.
6204 is offline
post #3 of 16 (permalink) Old 04-29-2009, 11:38 PM
The Professor
lance328's Avatar
You will not find cone filters with the odd mount shape needed.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #4 of 16 (permalink) Old 04-30-2009, 12:48 AM
Jace Bror's Avatar
and if you used the K&N cone air filters you would still need to rejet. the reason you have to rejet is because of the increased air flow that you get with the K&N and other high air flow filters. Now if you got some crappy ones to fit maybe then you wouldn't have to rejet. But finding one to fit is the problem. cuz the fitting on the back of 'ears' isn't round like most filters.
Sold 750 (9-09)
Mustand Seat (6-09)
Balanced Carbs (4-09)
Adjusted Mix Screws (4-09)
R/R Relocated (3-09)
Splines Lubed (3-09)
Painted flat blak (3-09)
Kuri grips (8-08)
Kuri Longhorn pegs (8-08)
Iridium Plugs (8-08)
Highway bar/ engine guard(FS)
Facebook ID Eli Gaffke
Jace Bror is offline
post #5 of 16 (permalink) Old 04-30-2009, 06:25 AM
Even if you modified the old tube to the air box, you'll still have to support the filter some how. I wouldn't trust it to stay.
post #6 of 16 (permalink) Old 04-30-2009, 08:17 AM
Newb with a Bullet!
krebsne's Avatar
Not to mention the best part of the earshave (to me) is getting rid of that g*ddman f*gly air box. If you haven't seen it, or realized you were seeing it, it's the oddly shaped plastic monstrosity that fills all the space between your carbs and the frame under the tank. Ear shave lets you cut that out of there and forever more getting in and working on your carbs or anything with the tank off is easier. Shoot I'd do it for that alone. Try taking the carbs off around that breather and you'll see what I mean.
The performance boost is just frosting on the cupcake as far as I'm concerned!
krebsne is offline
post #7 of 16 (permalink) Old 04-30-2009, 08:19 AM
Probably still need to rejet even with the cheapest/crappiest filters you could find.
I did a ride without the chrome/finned covers on the ears. Bike started and idled just fine. but around 4k rpms, the bike just wouldn't run properly. Too much air.
Possibly, if you'd add some sort of restriction to the filters, as in partialy covering them, you might not need to rejet.
post #8 of 16 (permalink) Old 04-30-2009, 11:25 AM
On His Lady Vulcan
wkrizan's Avatar
This guy did it.....
Pictures of the "Ladies"
wkrizan is offline
post #9 of 16 (permalink) Old 04-30-2009, 11:39 AM
He also said about that one.....
I have not to re-jett carbs.
But after first test ride it was a bit lean - I added a bit of air filter oil more, and got right mixture.
I'd guess that adding filter oil to the air filter didn't help for too long though.
post #10 of 16 (permalink) Old 04-30-2009, 11:45 AM
Simple Solutions
seebeeare's Avatar
IMO the amount of room u gain by removing that boc is all worth it trying to widdle more stuf into that area sounds like a pain....
i personally tried to come up with something for those ears when i put on the larger tank and the best solution i could come up with (to fit the tank was to fli them (like a clock)this gave me enough room for the tank.... but now that i shaved im lookin for another tank cant wait...
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
How To Test the Stator
seebeeare is offline
