1985 VN 700 interchangeibility with VN750's? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 04-29-2009, 02:25 PM Thread Starter
I have a 1985 VN700 and was wondering what parts, if any wouldn't work from a VN750?
ccolumber is offline
post #2 of 3 (permalink) Old 04-29-2009, 02:39 PM
From the Vulcan Verses...
I understand that for the most part the only difference between the 700 and at least the early 750's is the cc of the engine. Is this true?
Front brake master cylinder changed shape in 91 so the front brake lever is different also. They stopped using air assist front forks sometime after the first couple yrs and the wiring harness is different from the models with self canceling turn signals and those without. Other than that nothing I can think of. The 86 is exactly the same except for the motor paint and cc's Jax
Hey there Preach, most of the parts on my 85VN700 and 97VN750 are interchangable. The brake fluid resovior is different, as is the oil filter size of the threads on the filter. But for the most part i can change everything else.
I also have a VN 700. The only parts so far as I know that does not fit our bike Are the wide blade chrome levers. Apparently the brake lever changed in '89? Somewhere around that year. Wes
__________________________________________________ _______________
This might help too.......
Changes in the VN750 over the years
New Cost:
$5,500 (1985)
$5,500 (1987)
$5,500 (1988)
$_,___ (19__)
$6,090 (1995)
$6,090 (1997)
$6,090 (1999)
$6,190 (2000)
$6,190 (2002)
$_,___ (20__)
Air adjustable forks
- '85-'88 = only years
Brake master cylinder
- '85-'90 = rectangular
- '91-'06 = round
Brake Lever
- '85-'90 = same
- '91-'06 = changed
Clutch lever is the same for all years
Engine color
- '85 only = black
- '86- up = natural aluminum
Engine displacement
- '85 only = 699cc
- '86- up = 749cc
Fuel Cap latching
- '85-'87 = close without key
- '88- up = need key to close ????
Fuel Control Valve
- '85-'__ = RES - ON - PRI (Prime)
- '__-'__ = RES - ON - OFF
Fuel Tank rear vent tubes
- '85-'87 = none
- '88-'98 = tubes
- '99- up = none ????
Grab rails, Sissy bar, Passenger footpeg mounts
- '85-'86 = aluminum
- '87- up = chrome
Instrument bezels
-'85-'__ = aluminum
-'03-'up = chrome
Mirrors
- '__-'__ = rectangular
- '__-'__ = round
Oil filter
- '85-'94 = larger size 2.95" diameter
- '95 up = smaller size 2.76" diameter
Oil filter (mating) plate
- '85-'93 = 13169-1921 = 2.95" (75mm)
- '94 = 13169-1921 = 2.95" (75mm)
- '94 = 13270-1170 = 2.76" (70mm)
- '95 up = 13270-1170 = 2.76" (70mm)
Shock absorber
- '85-'98 = 45014-1304
- '99- up = 45014-1710 older ProTac brackets may interfer with air valve
reported by Jim "Pick" Foster
Side covers
- '85-'86 = Ebony
- '87-'98 = Chrome
- '99-'00 = Gray
- '01 only = Bronze
- '02 only = Black
- '03 only = Red
- '04 only = Ebony
- '05 ____ = _____
- '06 ____ = _____
Wheels
- '85-'86 = painted
- '87-'up = natural
Wiring harness
- '85-'88 have a Turn Signal Control unit
- '89- up Turn Signal Control unit eliminated.
- '85-'88 are NOT interchangeable with 1989 and up
Won't work by leaving the signal circuit open
__________
- '__-'__ =
- '__-'__ =
__________
- '__-'__ =
- '__-'__ =
Paint color listing:
http://f1.grp.yahoofs.com/v1/MKNSQ_P...D08M/color.xls
A # Year Tank colors Side cover
A 1 1985 _______ / _____ Ebony _____-____ & ____
A 2 1986 Black / Red L.V. Red 36002-5183-P5 & 5184-P5
A 2 86 Black / White Ebony 36002-5181-H8 & 5182-H8
A 3 1987 Black / Gray Chrome 36001-1359 & 1360
A 4 1988 Ebony / Gray " " " "
A 5 1989 Ebony " " " "
A 6 1990 Maroon / Black " " " "
A 7 1991 Maroon / Black " " " "
A 8 1992 Blue / Blue " " " "
A 8 92 Green / Green " " " "
A 9 1993 Blue / Gray " " " "
A 9 93 Green / Green " " " "
A10 1994 Green / Blue " " " "
A10 94 Red / Red " " " "
A11 1995 Green / Blue " " " "
A11 95 Red / Red " " " "
A12 1996 Red / Gray " " " "
A12 96 Blue / Silver " " " "
A13 1997 Red / Gray " " " "
A13 97 Ebony / G. Silver " " " "
A14 1998 Bronze / Red " " " "
A15 1999 Ebony / Gray P.C. Gray Blue 36001-1284-VK & 1285-VK
A16 2000 Ebony / Gray P.C. Gray " " "
A17 2001 Graystone / Bronze M.D. Bronze 36001-1284-7R & 1285-7R
A18 2002 Black / Silver P.G. Black 36001-1284-86 & 1285-86
A19 2003 Red / Graystone L.V. Red 36001-1284-2T & 1285-2T
A20 2004 Ebony / Silver Ebony 36001-1284-H8 & 1285-H8
A21 2005 Ebony / Silver Ebony " " "
A22 2006 _______ / _____ _______ -
post #3 of 3 (permalink) Old 04-29-2009, 08:19 PM Thread Starter
Thanks for that. Very thorough and very interesting!
