Whistling when decelerating? (in gear) - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 18 (permalink) Old 04-28-2009, 05:39 PM Thread Starter
He, i've noticed a moderately high pitched whistling noise when I'm engine braking. The noise starts at a higher pitch, then drops to a lower pitch as the bike slows down. The sound only happens wehn I'm in gear... if I slow down with the clutch lever pulled, the sound is gone. Any ideas?
dubious is offline
post #2 of 18 (permalink) Old 04-28-2009, 06:38 PM
Calif Rider
weh44att's Avatar
You can try with help to hold the bike. Put the bike up on the center stand, warm it up, put in gear eccelerate the engine. Stand close to it and try and hear where the whisle is coming from. Maybe then with where the sound is coming from somebody maybe able to help with a solution. I my self have not heard a sound like that on my bike at all.
2004 25,500 miles
Led tail light enhancement
Homemade floor boards
Headlight modulator
Extra heat sink on R+R
R+R relocation
Homemade driver's backrest
Fused Stator
Mcct conversion-cost 4.50
Ride-on in tires
iridium plugs
coil pickups adjusted.
weh44att is offline
post #3 of 18 (permalink) Old 04-28-2009, 07:08 PM
letitflight's Avatar
i had the same whistling too. and i think it's coming from the 'ears'(air filter).
sometime mine gets very noticeable during decelaration.
my 2 cents
PEACE!!!
2005 Vulcan 750
letitflight is offline
post #4 of 18 (permalink) Old 04-28-2009, 07:23 PM
Vulcans whistle when they are happy.
When was the last time you changed your oil and what did you use?
(clutches tend to wine, not whistle however)
Could be your helmet.
post #5 of 18 (permalink) Old 04-28-2009, 07:24 PM Thread Starter
Its not my helmet, because when I pull the clutch lever, the sound goes away. And it almost DOES sound happy! I took a girl on the bike and she thought it was cute sounding.
dubious is offline
post #6 of 18 (permalink) Old 04-28-2009, 07:40 PM
If girls like it... KEEP IT!
post #7 of 18 (permalink) Old 04-28-2009, 07:50 PM
The Professor
lance328's Avatar
Sounds like a clutch basket or output shaft bearing, or possibly bevel gear or final drive noise.
Check the final drive oil level.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #8 of 18 (permalink) Old 04-28-2009, 10:24 PM
try this: remove the ears(cover and filter only) and start your bike with the center stand, and let us know if it's still doing it, i bet you won't hear it anymore.
you can hear the whistle 'big time' when you use a video camera or just by recording it with a cheap recorder.
it sounds like when someone takes a hit from a bong (water pipe) but at a faster rate and higher pitch
cheers
PEACE!!!
2005 Vulcan 750
post #9 of 18 (permalink) Old 04-29-2009, 04:27 PM
Originally Posted by letitflight View Post
.....it sounds like when someone takes a hit from a bong (water pipe) but at a faster rate and higher pitch
Yah, there's a sound everyone is familar with.....LOL
You all came up with some pretty intresting diagnosis on this one. But as it seems to happen when downshifting/engine breaking I would bet a buck it is one of the reed valves.
Try "marbling" and see if it goes away.
(Marbling comes with the practice of sticking a marble in the hoses going to the reed valves to block them off)
post #10 of 18 (permalink) Old 04-29-2009, 04:56 PM
The Reanimater
jthill524's Avatar
Location: A Little Town Along I-5 in Northern California
OK.... It can't be a vacuum leak because they stay Constance. Since it changes with speed and goes away when you dis-engage the clutch. I'd have to say the noise is more a rubbing noise, like rubbing your finger around a wine glass.
Now the rear end, shaft, transmission and engine is still turning when you pull the clutch handle.
The answer could be one or more warped clutch plates.
JaY
"Veronica"
2002 VN750 Vulcan
Rebuilt Engine
ACCTs lubed w/TOC Springs
Pick-up Coils Gapped at .018"
Splines Lubed
Deka MF AGM EXT15L Battery
NGK Iridium IX Spark Plugs
R/R Relocation Fix
New Rear Rack
Stock Seat Repadded
Ext-BackRest
jthill524 is offline
