Universal Blue Racing Formula Sealant - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 04-28-2009, 03:11 PM Thread Starter
The Reanimater
jthill524's Avatar
Location: A Little Town Along I-5 in Northern California
Has anybody tried this? Looks like it might be good use with the gaskets on the side covers.
http://www.harborfreight.com/cpi/cta...emnumber=97824
Use on pre-formed gaskets, water and oil pumps, cylinder heads and sumps, inlet manifolds, timing case covers, gear box and transmission components, and finely machined surfaces, and for thread sealing
Polyester-urethane-based sealant transforms from a gel-like material into a resealable, non-setting, non-hardening putty within minutes of application
Offers unlimited assembly time and resistance to vibration and thermal expansion
-50 to 250 Celsius temperature range
Allows metal-to-metal contact
Resistant to combustion products, water, engine coolant, petroleum, lubricating oils, kerosene and fluorocarbon refrigerants
Seals surface imperfections
Flame, dust, and moisture proofing properties
JaY
"Veronica"
2002 VN750 Vulcan
Rebuilt Engine
ACCTs lubed w/TOC Springs
Pick-up Coils Gapped at .018"
Splines Lubed
Deka MF AGM EXT15L Battery
NGK Iridium IX Spark Plugs
R/R Relocation Fix
New Rear Rack
Stock Seat Repadded
Ext-BackRest
jthill524 is offline
post #2 of 3 (permalink) Old 04-28-2009, 03:44 PM
Usually, I question anything from HF as being all that reliable.
But, it searching 'Hylomar' (the maker of the sealant) it seems like a decent product. Can't say I've ever used it though.
post #3 of 3 (permalink) Old 04-28-2009, 06:21 PM
flyboy's Avatar
Hylamar is used in sealing the gear box front cover on the Rolls Royce RB211 jet engine. It is also used by many general aviation engine rebuilders to seal the engine case halves. Good stuff.
Ron
flyboy is offline
