poppin and missin at 6k - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 04-25-2009, 03:55 PM Thread Starter
Simple Solutions
seebeeare's Avatar
top 2 frontrest are the rear i believe my problem is in the rear...
Recent rebuild recent ear shave and degoat....
Here are a pic of my new plugs after 90 miles bike has a miss at 6000 rpms seems to be able to pull through in the lower gears but i cant get passed 80 took some pics of the plugs
ID:	1666   Click image for larger version
ID:	1667   Click image for larger version
ID:	1668   Click image for larger version
ID:	1669   Click image for larger version
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
How To Test the Stator
seebeeare is offline
post #2 of 8 (permalink) Old 04-25-2009, 04:51 PM
Did you rejet?? What pipes did you use when degoating??
post #3 of 8 (permalink) Old 04-25-2009, 05:00 PM Thread Starter
Simple Solutions
seebeeare's Avatar
rejetted 140, 40 stock pipes with 2 in flex to connect the headder to the stock muffler did not drill the baffles
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
post #4 of 8 (permalink) Old 04-25-2009, 05:04 PM
When I had the jardines and ear shave at the same time I had a problem running out of fuel. Meaning that the fuel mix was not right cause I did not rejet. I went back to the stock mufflers and the goat now the bike runs fine.
I don't know what your problem is.
post #5 of 8 (permalink) Old 04-25-2009, 08:02 PM
What's your A/F mix screw settings? Believe it or not, that can affect top end; so can a partially clogged idle circuit or pilot jet, or an improperly routed vent hose. I'm running 40 pilots, 140 mains, stock needles w/no shims, 3.75 turns out on the front a/f screw, 3.5 rear, and my vent hose is up under the top of the frame above the front cylinder, a few inches behind the steering head. Degoated, stock pipes, undrilled; she wraps right out to redline.
Every bike's different, tho; you may need to go to 142 on the rear, and/or one or two shims under the needle head(s). Beyond that, I can't tell enuff from the pics to judge; too fuzzy for my old eyes.
Jim
J.D.
Kerrville, TX
'95 Vulcan 750 "Therapy II",
aka "Raggedy Ann"
'95 VN750 project
'03 VN800B "The Little Black"
'04 VN800E Drifter project
'93 VN1500A custom project
VROC #16185
GCVROC #33
J.D. is offline
post #6 of 8 (permalink) Old 04-25-2009, 10:26 PM Thread Starter
Simple Solutions
seebeeare's Avatar
2 shims 2 and a half turns front and rear( pretty sure) vent hose is vented up underr the tank and has a breather attached ...
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
post #7 of 8 (permalink) Old 04-25-2009, 11:56 PM
The Professor
lance328's Avatar
Turn screws to 3-3 1/2 turns and see if there is any change.
Check throttle cables and make sure the butterfly will open all the way.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #8 of 8 (permalink) Old 04-26-2009, 02:05 AM
Yeah, forgot about that; and check they're opening the same amount at the same time (carbs synced). One other thing, make sure the choke is all the way off and both plungers all the way down; if one side or both is/are partially engaged, it can cause that (don't ask...)
Jim
J.D.
Kerrville, TX
aka "Raggedy Ann"
'95 VN750 project
VROC #16185
GCVROC #33
J.D. is offline
