Any painters here? - Page 2 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #11 of 18 (permalink) Old 04-26-2009, 03:28 PM
since your doing gloss black make sure you do a good job with the prep work... any imperfections are going to show whit the black.... so sand.... body filer... sand..... body filler.... sand..... body filer and sand untill everything is smooth to the touch.... your hand will show more imperfections that your eyes will pick up.... then spray the paint o the specs of the manufacture...(paint+reducer) spray.... let it flash... spray again... let flash.... and go until it is smooth and uniformly covered... if you do get a drip or a ripple dont worry too much.... you can take a razor blade when its dry and at a 90 degree angle you can srape off the paint on the run or sag little by little.... then hit the area with a light coat of black and your ready for clear.. clear coat it.... sand and buff....
bigrepp61 is offline
post #12 of 18 (permalink) Old 04-27-2009, 01:48 AM
dirtrack650's Avatar
When you say body filler, do you mean glazing putty for the final steps?
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #13 of 18 (permalink) Old 04-27-2009, 02:25 AM
I`ve got a question for the experienced painters here. I believe that factory paint jobs are baked in an oven, which gives them extra hardness and durability. Could an individual improvise an oven for a bike with some plywood and a couple of heat lamps? Also, would it be worth the time and effort?
post #14 of 18 (permalink) Old 04-27-2009, 02:49 AM
The Professor
lance328's Avatar
You would have to keep the temperature around 170 for a couple hours and have a circulation fan to evenly distribute the heat and a fan to exhaust the fumes to prevent solvent popping.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #15 of 18 (permalink) Old 04-27-2009, 08:57 AM
Originally Posted by Chiron View Post
One recommendation though...Go to the junkyard and pay like $20 for an older car fender that's a decent size to practice on. The older cars have more surface area and the fenders have all the areas to practice on. e.g. Flat, curved, tight edges, etc. It's one thing I didn't do that I should have. The practice would have saved me a lot of time and effort on my tank.
I have been waiting to do my own paint job on the bike. I actually have some artistic ability and would love to put it to the bike. This is a GREAT idea! One question: with all the sanding that's needed, does anyone know if power sanders work with this type of project? I don't want to cut corners but if I can save some momo down-time I will...
LibertyPilot is offline
post #16 of 18 (permalink) Old 04-27-2009, 02:00 PM
The Reanimater
jthill524's Avatar
Location: A Little Town Along I-5 in Northern California
My Uncle was a Body and Fender man for 40years. He showed me a little trick to remove the Original Paint if your doing a repair job. Now this only works on the Metal surfaces. Take a little Propane Torch and Heat/burn the paint on the spot you need to sand down. Then take a wire-wheel to it. It takes it off down to the metal.
Just don't over heat the metal.
The sanding the original decals and paint down took forever, even with 320 grit sandpaper.
JaY
"Veronica"
2002 VN750 Vulcan
Rebuilt Engine
ACCTs lubed w/TOC Springs
Pick-up Coils Gapped at .018"
Splines Lubed
Deka MF AGM EXT15L Battery
NGK Iridium IX Spark Plugs
R/R Relocation Fix
New Rear Rack
Stock Seat Repadded
Ext-BackRest
jthill524 is offline
post #17 of 18 (permalink) Old 04-27-2009, 05:02 PM
Hey JT --
Hmm, that's an interesting idea! I never thought about using heat to remove paint.
I recently painted my front fender and used spray-on paint remover from Advance Auto to remove the paint. Spray it on, wait about 20 minutes and wipe it off with a wet rag. I was surprised at how well it worked!!
FlaRider is offline
post #18 of 18 (permalink) Old 04-27-2009, 05:36 PM
dirt track - yeah i forgot that step... thanks for pointing that out....
and liberty pilot.... yeah you can use an electric or pnumatic sander but once you take the majority off you will want to go by hand because you cant get the same contours... either use a sanding sponge.... (looks like a long brick that is very flexible) or if you cant find one or dont have one just ise a normal dish sponge with the paper around it.. that way you dont sand more where your fingers are pressing.. again like said earlier... $800 for someone to do it bus alot of supplies to do it yourself and then you know how to do it afterwards...
