vn700 verses vn750 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 04-16-2009, 01:30 PM Thread Starter
vn700 verses vn750
Can anyone tell me if the parts from a vn700 will work on a vn750 I found a vn 700 for $350 an thought about buying it for parts if the interchange. Can anone help?
Rebel is offline
post #2 of 12 (permalink) Old 04-16-2009, 02:02 PM
The Professor
lance328's Avatar
ALL parts are the same except, pistons, cylinder sleeve, 89 up left bar switch and 91 up master cylinder.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 12 (permalink) Old 04-16-2009, 02:19 PM
Originally Posted by lance328 View Post
ALL parts are the same except, pistons, cylinder sleeve and master cylinder.
Just need a clarification, lance. I knew the front brake master cylinder changed from a rectangular to a round shape sometime before the `91 models came out, (my `91 is round). I thought that both the `85 US model 700 and all early 750`s came with the rectangular master cyl for a few years.
post #4 of 12 (permalink) Old 04-16-2009, 02:21 PM
The Professor
lance328's Avatar
Looks liks I was modifying as you were posting.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #5 of 12 (permalink) Old 04-16-2009, 02:26 PM
93VN750's Avatar
I believe the heads & head gaskets are different. A few 700 owners have had major problems finding the head gaskets since they are no longer in production.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #6 of 12 (permalink) Old 04-16-2009, 03:21 PM
The wiring harness is different too.
The 700 and early 750's had auto cancelling turnsignals. Trying to just eliminate the auto circuit (IIRC) doesn't work.
post #7 of 12 (permalink) Old 04-16-2009, 04:10 PM Thread Starter
Thanks I'm going to go look at this critter tomorrow so could have some spare parts if anyone needs them the man said there was no title. If I can get it running might try for a title according to it's condition the man said it was in storage since 1992 it's a '85 with 22000 mi. Thanks for the input
Rebel is offline
post #8 of 12 (permalink) Old 04-16-2009, 06:33 PM
The Professor
lance328's Avatar
Jon
Heads and head gasket are the same, the head has a different part # because of the color. The head gasket is the same part #, you can go to any dealer and order any part for the vn700. I don't know why they had problems finding head gaskets.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #9 of 12 (permalink) Old 04-17-2009, 07:13 AM
Simple Solutions
seebeeare's Avatar
i know this was a few posts ago but my 91 is rectangle....
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
How To Test the Stator
seebeeare is offline
post #10 of 12 (permalink) Old 04-17-2009, 07:38 AM
The Professor
lance328's Avatar
If your 91' has a rectangular M/C it was replaced, 90' was the last year for that M/C. They will swap with no problem, the lever is different.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
