Upgrade - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 05-04-2020, 09:35 AM Thread Starter
Upgrade
Hi,
I have a 1985 VN700 need to change the engine can anyone advise what engines will fit,
Would like either the 750 or 900
Thanks for your time
Glyn
Glyn Jones is offline
post #2 of 11 (permalink) Old 05-04-2020, 09:55 AM
the vn750 engine is identical to the 700 with exception of displacement. bolt in. connect the couple of wires, done. vn900 is totally different
michiganteddybear is offline
post #3 of 11 (permalink) Old 05-04-2020, 09:57 AM
The Vulcan 750 engine is almost exactly the same, and will bolt right in with zero modifications. I donít think the 900 would fit.
The only difference really between the 700 and 750 is the size of the bore, everything else is interchangeable thatís not directly tied to that.
post #4 of 11 (permalink) Old 05-04-2020, 10:20 AM
MSattler's Avatar
I have heard people claim their 700 is faster than their 750. Could that be due to the smaller bore size? My 700 is still missing it's carb, until the piece from the UK comes in, so I cannot test this theory.
'08 Road King Classic
'86 VN750:
Ear Shave, K&N Filters, Mean Streak Seat, AGM battery, Blue Wire Mod, Pick-up Coil Mod, Timing Advance Mod, NGK Iridium Plugs and Wire, LEDs, Bed Liner Paint Job, Over-sized Tires, New Brakes, New Fork Seals, Progressive Springs, Kick Stand Mod, Highway Pegs, 40/140 No Shims, Vance & Hines Exhaust, New Grips, Extra Wide Emgo Handle Bars
John 8:44, REV 2:9, REV 3:9 - If you were kicked out of 109 bars, would you think the problem was you, or the 109 bars?
MSattler is offline
post #5 of 11 (permalink) Old 05-04-2020, 10:41 AM
Agreed to MTB and KM. 700-750 or buy another bike to ride.
Would have to see the 700 be quicker than 750. But I know a Kaw 440LTD is quicker off the line than a Yamaha 750 Special (3cyl), about 3rd gear the Yamaha wins. LTD is a lot smaller frame thoguh.
post #6 of 11 (permalink) Old 05-08-2020, 12:29 PM
Jason Pittenger's Avatar
Does the 700 rev any higher than the 750?
Completed modifications:
Planned modifications:
Jason Pittenger is offline
post #7 of 11 (permalink) Old 05-08-2020, 12:52 PM
Nah, same engines, just tiny bit smaller bore on the 700. Put nitrous on either one, it will rev higher. Then has no choice, blend or mulch.
post #8 of 11 (permalink) Old 05-08-2020, 04:18 PM
9500+ outta a v-twin not revving enough for ya?
post #9 of 11 (permalink) Old 05-08-2020, 06:13 PM
🙂 haha I've seen 10k on purpose, maybe 12 accidentally. Pretty sweet v-twin. Locals hear a sportbike wailing through town and all they see is an old geezer on a cruiser..
I like being earshaved with stock pipes, it's only loud when I make it loud.
post #10 of 11 (permalink) Old 05-08-2020, 07:03 PM
HAHAHAHA!!!
I was just curious. The 750 only hits (or should only hit) 8500 redline.
I know it'll rev past 11, because I missed a 1st-2nd shift and gunned it in neutral!
I don't advise it...
I found no usable power > 8500. What are you doing at 10k?!?
Once I get my bike running again (and stumble upon $250 or so), I'm going to put on a programmable ignition.
I suspect the power fall off after 8k is due to no ignition advance after 3.5k.
Looking online at various engines (I know, all engines are different), many show increasing advance all the way up to redline.
It might just be the RPM that it runs out of steam.
