Upgrade - Page 2 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #11 of 11 (permalink) Old 05-08-2020, 11:06 PM
Originally Posted by Jason Pittenger View Post
Nah, same engines, just tiny bit smaller bore on the 700. Put nitrous on either one, it will rev higher. Then has no choice, blend or mulch.
HAHAHAHA!!!
Originally Posted by michiganteddybear View Post
9500+ outta a v-twin not revving enough for ya?
I was just curious. The 750 only hits (or should only hit) 8500 redline.
I know it'll rev past 11, because I missed a 1st-2nd shift and gunned it in neutral!
I don't advise it...
🙂 haha I've seen 10k on purpose, maybe 12 accidentally. Pretty sweet v-twin. Locals hear a sportbike wailing through town and all they see is an old geezer on a cruiser..
I like being earshaved with stock pipes, it's only loud when I make it loud.
I found no usable power > 8500. What are you doing at 10k?!?
Once I get my bike running again (and stumble upon $250 or so), I'm going to put on a programmable ignition.
I suspect the power fall off after 8k is due to no ignition advance after 3.5k.
Looking online at various engines (I know, all engines are different), many show increasing advance all the way up to redline.
It might just be the RPM that it runs out of steam.
What am I doing? I'm watching the doggone road like turkey buzzards shopping for roadkill on date night. 🙂
North of 100. But after a certain level your not needing more power, it's time, speed, and distance your making.
We can chuck up the lathe and make those ashtrays, and you won't have to cook'em up out there on the road. 🙂
If you dial up too much timing at full throttle, it won't blend or mulch, it will most likely just cook itself. You'll surpass the ability of gasoline to keep the combustion cool.
"She runs 4:03 in the 1/4 mile, on aluminum" 🙂
Don't let it be lean.
Since you're experimenting with time, find out what the red/white wire does. It's a mystery baffling some Vulcan old dude.
We might find a 'push to pass' circuit to mod with.
