Bolt sizes for rear luggage rack... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 04-15-2009, 02:43 PM Thread Starter
wvshaneb's Avatar
Need some help. I got a rear rack from ebay, said it was new, but didn't come with any bolts for mounting. I'm guessing the existing bolts in the seat rail will work for that part. I did see in a previous thread that knifemaker suggested a bit longer bolt for these. No problem there, just take the existing one and get a longer version of it. What I don't know is what size to get for the part that bolts to the cross piece under the seat. If anyone knows, please share.
Thanks!!
Mom, I'm not wearing my helmet only for the purpose of taking this picture and
the background was digitally blurred to make it look like I'm going really fast.
wvshaneb is offline
post #2 of 8 (permalink) Old 04-15-2009, 03:44 PM
phurp's Avatar
did you get the oem kawasaki rack? if so , I have one on my bike and will check this evening about the size.
1990 vn-750
metzler 880's
r/r relocated
iridium plugs
ngk plug caps
mf agm battery
ballancer and stator replaced. (Lance328)
Pro Tac Backrest
progressive fork springs
fork seals replaced
2003 kdx 220
frp chain gude
frp skid plate
acerbix hand guards
uni filter
phurp is offline
post #3 of 8 (permalink) Old 04-15-2009, 04:00 PM Thread Starter
wvshaneb's Avatar
It is the OEM rack, and the info will be much appreciated!
wvshaneb is offline
post #4 of 8 (permalink) Old 04-15-2009, 06:34 PM
phurp's Avatar
the bolts have a 13 mm head, the shaft is 8mm x 20mm the thread is 1.25. mine has a flat washer and a lock washer.
1990 vn-750
metzler 880's
r/r relocated
iridium plugs
ngk plug caps
mf agm battery
Pro Tac Backrest
fork seals replaced
2003 kdx 220
frp chain gude
frp skid plate
acerbix hand guards
uni filter
phurp is offline
post #5 of 8 (permalink) Old 04-15-2009, 07:04 PM Thread Starter
wvshaneb's Avatar
Thanks to the info. Off to the hardware store after supper.
Update:
The bolts for the seat rails have 10mm head, 6mm x 20mm shaft(6 x 16 aren't quite long enough, found that out the hard way) and threads are 1.00
wvshaneb is offline
post #6 of 8 (permalink) Old 04-18-2009, 01:17 PM
Update:
Use some 'blue ' thread lock, bolts rattle loose very easily on bikes.
Mastertech is offline
post #7 of 8 (permalink) Old 10-07-2010, 12:01 PM
For the side rail bolts the correct dimensions are 10mm head, 6mm x 20 mm shaft but for the bolts that go down toward the fender, on my bike the 10mm heads are too small. Is it possible Phurp was referring to the fender bolts being 13 mm heads, 8mm x 20mm with a 1.25 pitch??? I'll try it out today.
Use blue thread lock!
Yup: 10mm head, 6mm x 20mm shaft bolts with a 1.00 pitch hold the luggage rack to the sides of the sissy bar. You need four of them. 13mm heads, 8mm x 20mm with a 1.25 pitch for the bolts that insert towards the fender. You need two of these.
BikeWheel is offline
post #8 of 8 (permalink) Old 10-25-2010, 06:38 AM
KIMMERLING's Avatar
cool
Ventura guards
MadStadt mount
Givi windshield/Heated grips
Backoff
Riderbeads
Givi 52 topcase
OEM centerstand
Headlight modulator
Battery tender
KIMMERLING is offline
