Found an engine paint I like - Page 2 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 5Likes
post #11 of 18 (permalink) Old 04-16-2020, 03:06 PM Thread Starter
I'm a rider
One1's Avatar
I have 500 miles on this paint and it hasnít turned or anything. Still looks good. I did paint the exhaust flange and it went golden color after enough heat on it. Must be an upper limit to the paint at some point but not on the engine.
1981 KZ750
1988 Vulcan VN750 (red)
2005 Vulcan VN750 (silver)
(2) 1994 Vulcan VN750 (red)
One1 is offline
post #12 of 18 (permalink) Old 04-24-2020, 10:27 AM
Diesel Tech
DenverDiesel's Avatar
Looks good, thanks for the info! Definitely use it on my wheels next time I have them off.
1989 VN750
Highway blaster
2006 Honda Rebel Diesel
100mpg, low and slow
1982 Mercedes 300D
Modified engine, 4-speed manual
DenverDiesel is offline
post #13 of 18 (permalink) Old 04-24-2020, 11:54 AM
Jason Pittenger's Avatar
That looks great! LOVE LOVE LOVE!
My engine is out for repairs, and full of stains from leaking coolant. I'd love to repaint!
Can you describe your process in detail?
I know very little about painting, so do I need to prime first? Sand?
What did you use to clean before painting?
Thank you!
Completed modifications:
Planned modifications:
Jason Pittenger is online now
post #14 of 18 (permalink) Old 04-24-2020, 03:56 PM
mmart's Avatar
Here’s a dumb question, did you paint the engine while still in the frame? Or are they all just before and after pics from your build?
mmart is online now
post #15 of 18 (permalink) Old 04-25-2020, 12:43 PM Thread Starter
I'm a rider
One1's Avatar
Degreased the engine, wiped with acetone, masked up everything that wasnít engine or bits i wanted to paint.
1981 KZ750
One1 is offline
post #16 of 18 (permalink) Old 04-25-2020, 02:35 PM
mmart's Avatar
Ah ok, sounds tedious, but doable. I asked because my engine is looking a little grizzled and could use it. My rims could probably use it too.
mmart is online now
post #17 of 18 (permalink) Old 04-26-2020, 12:39 AM Thread Starter
I'm a rider
One1's Avatar
15 mins prep. That paint is very good coverage so two shots about 3 to 5 mins apart.
1981 KZ750
One1 is offline
post #18 of 18 (permalink) Old 04-27-2020, 04:11 PM
I bought a can today for the engine (wheels will wait for now). I might go black gloss on the wheels....
I also saw Dupli-Color had an engine enamal primer, and an engine enamal clear coat. Should I use these? The can also recommended I run scotchbright over the surface before painting. Should I? What about areas where the paint seems to be chipping off? Will the Acetone damage any of the gaskets? Should I cover/mask off the gaskets when spraying?
Forgive my questions, my paint knowledge is close to 0. My first attempt at painting my gas tank resulted in fogging when gas touched it. Second attempt, it wrinkled the first time it saw the sun. I've gotten compliments on the wrinkle, so I'm keeping it, but it wasn't the desired surface finish. When I painted my truck, the paint bubbled!
As a result of these mis-haps, I want to make 100% sure I do everything exactly right, because what I thought I knew was wrong.
