Importance of cylinder base gasket? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 03-21-2020, 02:17 PM Thread Starter
rerb's Avatar
I seem to have a slow coolant leak coming from the cylinder base gasket. Not the head gasket, but the one below it connecting the jug to the bottom end. The bike has a bit of foul-smelling white smoke when it's cold, but there doesn't seem to be a leak from the head gasket. Is it that important to go through the trouble of pulling and tearing down the engine for the base gasket? or am I safe to keep riding it for the season? thanks.
rerb is offline
post #2 of 6 (permalink) Old 03-21-2020, 03:32 PM
Some have gotten by letting it leak a while, but it's never good. Antifreeze is hard on bearings, and burning coolant reduces lubrication on the cylinder walls.
Some will only leak when cold. Keep an eye on the oil.
post #3 of 6 (permalink) Old 03-21-2020, 04:40 PM Thread Starter
rerb's Avatar
Will do, thanks. It's still pretty cold here, 30s to 40s.
rerb is offline
post #4 of 6 (permalink) Old 03-21-2020, 07:27 PM
I'm a rider
One1's Avatar
Be certain it’s not coming from the o-ring above it at the coolant hose going into the head. Gravity is a funny thing and the coolant tends to ride the inside of the fins down so it isn’t obvious.
1981 KZ750
1988 Vulcan VN750 (red)
2005 Vulcan VN750 (silver)
(2) 1994 Vulcan VN750 (red)
One1 is offline
post #5 of 6 (permalink) Old 03-26-2020, 10:12 PM
The Vulcan 750 base gaskets are very flimsy. Only about a 1/16" between the coolant passages and edge of the cylinder. If it is leaking coolant into the oil, it needs to be fixed. Coolant and oil mixed together make glue. Not only does it not lubricate well, but it plugs everything up.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #6 of 6 (permalink) Old 03-29-2020, 01:12 PM Thread Starter
rerb's Avatar
I should be able to tell if it's mixing with the oil by looking through the sight glass, right? Or is this something I need to drain the oil for?
rerb is offline
