Windshield vs Fairing - Page 2 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #11 of 17 (permalink) Old 11-04-2019, 10:46 AM
mmart's Avatar
That’s the spitfire cheapee by the way. Around a $80-100, makes a big difference and IMO looks good on an 80’s style machine
mmart is offline
post #12 of 17 (permalink) Old 11-04-2019, 01:26 PM
Retired USAF (IYAAYAS)
Chris and Shim's Avatar
For years I used a PlexiFairing 3 and really liked the protection it gave. I switched it out for a National Cycles Low Boy Heavy Duty windshield which also gives good frontal protection but does nothing for my hands.
I think the National Cycles definitely looks better and will give much better protection if you get a serious impact from something heavy vs the PlexiFairing but the PlexiFairing gets the nod in pure wind protection. And as stated earlier, just paint it and it'll look similar to a batwing type of arrangement. But it'll be cheaper.
I'm going to stick with the National Cycles since it is much clearer than the older PlexiFairing (simply due to its age) and since my sister-in-law gave me some good gloves that extend over the edge of my jacket's arm the wind affecting my hands (and what was blowing up my jacket arm) has been almost entirely deleted.
But for you, I'd recommend the PlexiFairing 3. Add on some home made lowers and you will discover you'll much more enjoy those high speeds.
Saddlebags, hard mounted
Fork mounted tool bag (now hard mounted)
Relocated rear turn signals
LED turn signals, brake lights and running lights
LED license plate frame
Engine Guard and Highway pegs
Home made lowers (nice)
Custom seat (made by a local guy)
Iridium plugs (DPR7EIX-9)
Shenko 230 Tour Master tires at 11,123 miles
Splines lubed at 11,123 miles
Luggage rack
Light bar with LED lights
Progressive 412 shocks
Chris and Shim is offline
post #13 of 17 (permalink) Old 11-05-2019, 11:41 AM
ubertalldude's Avatar
I rock a Slipstreamer S-03 windshield that's about as big as a fairing. It has cover for my hands, rises high enough to get my head completely out of the wind, and even wraps around down behind the turn signals to provide a touch more wind protection. I like it quite a lot, keeps me from getting too fatigued on long trips, I can duck behind it fully in heavy rain, and keeps my hands out of the wind on cool days.
ubertalldude is offline
post #14 of 17 (permalink) Old 11-10-2019, 11:22 PM Thread Starter
boscoe's Avatar
According to Amazons "fit check", this will not fit an 04 Vulcan 750. PlexiFairing 3 Hopefully, this is just a computer glitch?
boscoe is offline
post #15 of 17 (permalink) Old 11-10-2019, 11:24 PM Thread Starter
boscoe's Avatar
According to the online "fit check", the Slipstreamer S-03 will not fit an 04 VN750. Hopefully this is a computer glitch?
In God we trust. All others pay cash.
boscoe is offline
post #16 of 17 (permalink) Old 11-11-2019, 12:32 AM
The PlexiFairing 3 will 100% fit the Vn750. Since Ubertalldude runs with the Slipstreamer S-03 then it apparently will also fit just fine.
Luggage rack
post #17 of 17 (permalink) Old 11-12-2019, 06:29 PM
I have a Memphis Shades "shooter" windshield on the Vulcan 750 It is too low to provide any real protection, but it is also low enough that it does not cause helmet buffeting. I mostly have it just for looks and a place to put stickers. I have tried several taller windshields, and they caused EXTREME helmet buffeting. Bad enough that my neck hurt after only a short time, and a roar that sounded like standing behind an F-16 at full throttle take off. Even ear plugs didn't help much. I did discover that if a windshield is a few inches above the top of your head, it will work. But there are problems with that idea as well. First you cannot see over it, and around here a windshield gets really dirty really quick, and the sunlight reflecting off the dirt makes it almost impossible to see through after a short ride. Cars have windshield washers for a reason. The other issue is that a handlebar/fork mounted windshield of any size acts like a sail, and a wind blast can literally yank the bars right out of you hands. (https://www.denniskirk.com/memphis-s...prd/230379.sku)
I have tried several windshields over the years, they only ones I didn't have problems with were the really low ones, which don't really do anything. I have had no problems riding without a windshield for hundreds of thousands of miles on the freeway in low temperatures. I wear a full face helmet, a CHP (California Highway Patrol) leather jacket that weighs about 25 pounds, and Widder heated gloves. Yes, for a short ride that super heavy jacket is an issue, it is hard to put on, hard to take off, what do you do with it while it is off, etc. It also restricts your movement on the bike. But on long rides none of that really matters. Absolutely no cold wind gets through that jacket. You can stay warm in it below 32 degrees.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
