And The Journey Begins........... - Page 2 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #11 of 77 (permalink) Old 04-10-2009, 10:00 PM Thread Starter
The Reanimater
jthill524's Avatar
Location: A Little Town Along I-5 in Northern California
Ok, Went and did a check over and called the HD Guy to see just what He did.
All He did was try a Compression test but the engine would't turn over. So He checked the water and oil and seen there was some mixture there. That was all.
He thinks sombody ran it without oil or water and froze something up.
I put a good battery in and He's right it won't turn over plus I can only click the shift lever once down. Then back to Netural. No up shifter click. Clicked the Shifter down but can't get the rear wheel to turn. Something must be locked up.
Found these wires draging on the ground, The 3 yellow ones are cut. I found where they should be.
I hate to look anymore..........But Looks like just pull the engine and go from there.
jthill524 is offline
post #12 of 77 (permalink) Old 04-10-2009, 10:27 PM
Simple Solutions
seebeeare's Avatar
the 3 yellow wires look like stator wires... try to pull the front stator cover and see if u can turn the motor backwards i know we are probbably delaying the inevitable and maybe just pull and admire would be the best bet all though it would be nise to turn the motor and see the operations of the cams ect...
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
How To Test the Stator
seebeeare is offline
post #13 of 77 (permalink) Old 04-10-2009, 10:30 PM
Simple Solutions
seebeeare's Avatar
well do u have the receipt for that batt? u should get a mf agm batt...
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
post #14 of 77 (permalink) Old 04-10-2009, 11:22 PM Thread Starter
The Reanimater
jthill524's Avatar
Pulled the cover but didn't see any way to turn the motor from there.
JaY
post #15 of 77 (permalink) Old 04-10-2009, 11:29 PM
The Professor
lance328's Avatar
Did you pull the left cover with the three screws? In the center is a 17mm crank bolt, normal rotation is counter clockwise.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #16 of 77 (permalink) Old 04-10-2009, 11:35 PM
that looks almost exactly like mine 6 weeks or two months ago,color and all except for that very artistic heart
post #17 of 77 (permalink) Old 04-11-2009, 12:00 AM Thread Starter
The Reanimater
jthill524's Avatar
Lance328:
There were threads where a big bolt could screw into but no bolt.
JaY
post #18 of 77 (permalink) Old 04-11-2009, 02:34 AM
The Professor
lance328's Avatar
Originally Posted by jthill524 View Post
Lance328:
JaY
Apparently the engine has been out and partialy tore down then slapped back together. Looks like the harley mechanic bit off more than he could chew. I would seriously consider buying a good used engine. Depending on your mechanical ability and parts needed to repair it might be your best bet.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #19 of 77 (permalink) Old 04-11-2009, 04:00 AM Thread Starter
The Reanimater
jthill524's Avatar
The HD Guy didn't pull or take apart anything.
Like He said " I have enough HDs here to work on and don't need to or have the time to work on any Rice Burners". It had to happen before the lady got it.
That's My Luck.....If somebody Crapped on it, I'll be the one that winds up with it. But then that makes Me who I am.....The One who fixes what others give-up on.
JaY
post #20 of 77 (permalink) Old 04-11-2009, 04:51 AM
The Professor
lance328's Avatar
JaY
That motor has been pulled, I can tell by the hose clamps, clutch cable routing and the wrench marks on the mount bolts.
Pull the motor and tear down and find out what happened then go from there.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
