Bike lost power - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 08-31-2019, 01:22 PM Thread Starter
Bike lost power
I recently had my stator replaced and just got the bike back from the shop a couple of days ago. Last night I was riding home and while I was sitting at a red light, I clicked it into first gear and the bike shut off and lost all power. Now when I put my key in the ignition the dash lights, headlights - nothing turns on. It makes no sound when I press the start button. It appears to have no power at all. I checked the battery terminals and they are tightly connected, so I know it’s not that. Do you think this is a larger issue having to to do with the stator or is it a loose wire kind of deal? What do you think the move is at this point?
Chris Childs is offline
post #2 of 3 (permalink) Old 08-31-2019, 01:50 PM
mmart's Avatar
I’d definitely go through the wiring connections considering what you just had done. Check for any blown fuses and/or something touching ground. Also check the battery voltage, if it has any good juice it would at least try to start. So beings that it’s completely unresponsive it sounds like a connection being open or shorted out
mmart is online now
post #3 of 3 (permalink) Old 08-31-2019, 02:12 PM
Check the elec. plugs under the left neck cover, and at the ignition switch, could also be dirty contacts in the ign. switch.
