RPM hangup - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 08-05-2019, 01:59 PM Thread Starter
RPM hangup
Hey guys got a VN750, (first bike) I'm a pretty sound mechanic with cars but I don't have a first clue with bikes this is a learning process for me. When I start the bike with choke, let it warm up, release the choke and let it idle after adjusting the idle switch it idles perfectly right at 1100 RPM, when I start driving the RPMS get hung up between 3k-4k, sometimes when I try to force the throttle closed by pushing forward on it the RPMs drop back to normal, sometimes they don't. Can anyone point me in the right direction on fixing this? I'm assuming it's an issue with the throttle cable but I could be wrong
Hunter Toney is offline
post #2 of 4 (permalink) Old 08-05-2019, 02:18 PM
mmart's Avatar
There’s 2 cables, and accelerator and a decelerator, they could be sticking or there could be an air leak in the carb, if it sucks in too much air it’ll rev erratically
mmart is offline
post #3 of 4 (permalink) Old 08-05-2019, 02:18 PM Thread Starter
Apart from that the only issue with the bike is it has a gas cap that's kind of just dangling open, previous owner jammed the key and got it stuck so it will not close correctly. Don't know if that could cause a lean condition or not but just thought I'd throw that out there
post #4 of 4 (permalink) Old 08-05-2019, 02:35 PM
mmart's Avatar
The cap has a small opening in it anyway to not cause a vacuum lock, I’d be more worried about something getting in there then it impacting how the bike runs.
mmart is offline
