The unsalvageable tank - Page 2 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 2Likes
post #11 of 18 (permalink) Old 07-10-2019, 11:42 PM Thread Starter
I'm a rider
One1's Avatar
Originally Posted by Thorn View Post
Once it gets rusty enough, you can use it as a rustic punched-tin lamp.
I've stuck LED's in tons of things before and I have a strip with a remote control and programmable brain. It may end up lit before it's over.
1981 KZ750
1988 Vulcan VN750 (red)
2005 Vulcan VN750 (silver)
(2) 1994 Vulcan VN750 (red)
One1 is online now
post #12 of 18 (permalink) Old 07-10-2019, 11:43 PM Thread Starter
I'm a rider
One1's Avatar
Originally Posted by flitecontrol View Post
If restoring it is worth the effort to you, the existing liner can be removed with paint stripper. Use good quality stuff and give it time to work. With all the liner removed, fill the tank with water and tape over the holes. When the tank is completely dry (doesn't matter if some flash rust forms) use Caswell epoxy tank sealer. It actually adheres to light rust even better than smooth metal. You'll never have to worry about rust again because the metal is entirely covered with epoxy on the inside. https://www.caswellplating.com/epoxy...nk-sealer.html
It's wall art. I don't need it. The POR15 they used before peeled back up when the metal split from the extensive rust damage.
1981 KZ750
One1 is online now
post #13 of 18 (permalink) Old 07-10-2019, 11:43 PM Thread Starter
I'm a rider
One1's Avatar
Originally Posted by VN750Rider/Jerry View Post
I have seen tanks so rusty the whole sides and top caved in. If it is that rusty it will have no structural strength,
It's still amazingly solid, just swiss cheese. I'm a welder and I do sheetmetal sometimes. I've been planning on making a gas tank for one of my VN's and I'm going to use this one for a template for the bottom so I know it'll fit the frame.
1981 KZ750
One1 is online now
post #14 of 18 (permalink) Old 07-12-2019, 04:46 PM
flitecontrol's Avatar
I had a similar issue with my VN750. Kawasaki dealership told PO it needed to be sealed and used what I assumed was Kreem. It rusted underneath the coating, causing it to fail. I used several quarts of paint remover to get the sealant out, then used The Works toilet bowl cleaner, which is 18% HCL, to remove the rust. Tank is still nice and shiney 10 years later. I top the tank off after every ride to minimize corrosion, and ethanol gas absorbs what little condensate that may form.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #15 of 18 (permalink) Old 07-13-2019, 11:23 AM
Too bad it's in such sad shape. As you can weld, it would have made a great candidate for building a higher volume tank with it. Someone awhile back did this by splitting the tank along the sides and adding a strip of metal. Increased capacity to about 5 gallons...
post #16 of 18 (permalink) Old 07-15-2019, 12:15 PM
Stone Poet. Kcdqg has it now. If I can find pics I'll dig em up
Sent from my A502DL using Tapatalk
One1 likes this.
post #17 of 18 (permalink) Old 10-04-2019, 12:19 PM
Thanks for sharing the information..
CharlieTheodore is offline
post #18 of 18 (permalink) Old 11-03-2019, 04:54 PM Thread Starter
I'm a rider
One1's Avatar
A pictorial review of why POR15 doesnít work and peels back out. I donít know who did this to this tank, but if it were me Iíd use muratic acid, naval jelly, THEN SEALER and cross my fingers. As bad as this tank is inside, I canít imagine they used anything before putting the sealer on.
ID:	46751   Click image for larger version
ID:	46753   Click image for larger version
ID:	46755   Click image for larger version
ID:	46757   Click image for larger version
1981 KZ750
One1 is online now
