Converting from KPH to MPH speedo - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 06-22-2019, 07:41 AM Thread Starter
Hi Everyone. I have a quick question and i'm not sure which category it should be placed. I'm just finishing a rebuild of a 1995 750 that was imported from Spain into the UK, its in great condition for the year because of the lack of rain and salt. My question is... Its a Kilometers per hour speedo and I want to switch to Miles per hour. I can get a little mechanical converter that changes the speedo cable ratio but the clocks usabe display is condensed down to a third of its display. If I switch to a miles per hour front wheel pickup for the speedo and switch the speedo to an imperial version I assume i'm sorted. I guess the confirmation I'm after is that there's no difference in the actual wheel just the pickup and speedometer. Thanks.
Martync is offline
post #2 of 6 (permalink) Old 06-22-2019, 09:01 AM
2003 Vulcan 750/Sidecar
Hench's Avatar
Hello
I have a cheap Chinese scooter for short trips in town. Speedo is in kilometers. I've found that multiplying the first digit of the speed by 6 gives a "guestimate" of MPH.
Maybe that will help until you do the mechanical stuff.
Cheers!
2003 VN750
Velorex 562 sidecar w/trunk
2-wire mod
Headlight power switch
Manual fan switch
Shingigen SH775
Blue wire mod
Yellow wire mod
RLU removed
RR moved
Voltmeter relay wired
Coils direct wired w/relay
handicap mods:
extended foot shift
heel shifter
extended brake pedal
Hench is offline
post #3 of 6 (permalink) Old 06-22-2019, 09:03 AM
NewB to Vulcans
TonyO's Avatar
Mine has both markings although he KPH is a not very obvious blue and smaller typeface.
I would bet they just change the faces, not the gearing or internals.
If you use a GPS then you will get a more accurate speed than the sppedo.
'99 Vulcan "Victoria"
TonyO is offline
post #4 of 6 (permalink) Old 06-22-2019, 09:58 AM
My guess is, no difference in the wheel. Would be a huge expense for the manufacturer to make a different wheel for KPH.
post #5 of 6 (permalink) Old 06-22-2019, 12:28 PM
Honestly I have found that there are only a few "speeds" you need to know when riding.(depending where you live and if your intent is just to avoid a ticket.)
I put a tiny dot of red floresant paint at 60 mph on the edge of the bezel and a yellow one at 45, the two most popular speed limits here. Thus I just can see at a quick glance how fast I am going.
There are simple kpm to mph calculators online. Just pick the speeds you need to know and mark them.
The only other option is to find a user working speedometer that has mph on it.
I really don't pay much attention to the thing anyway...
post #6 of 6 (permalink) Old 06-22-2019, 12:50 PM
Even if converted, without the oversize front tire, it's still off. Isn't it? Consensus is, yes, with stock size the indicated speed reads 5 mph faster than actual speed, so you'll always be slower this way.
Never rode with a stock size front, so didn't check. But i know with oversize it's within 1mph with the oversize, checked six ways.
