VN 750 blues .1st ride around the block. Short lived - Page 3 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 6Likes
post #21 of 31 (permalink) Old 06-05-2019, 11:42 PM Thread Starter
Originally Posted by Ron Ryman View Post
I joined the 2 wires once cut from pig tail. but the 2 left hanging attached to plug in I did not connect so they are taped at the ends. Do i connect them togather to return into J.B.?
Sent from my SM-J700T1 using Tapatalk
Having started the bike and riding it. wouldn't that be a load test. still having 12.8 volts. there was 13.3. 3 days ago when The lights went out in Md.lol. Im sanding the grounds. and looking under the tank where I reconnected the ignition wires. I did a continuity test at Jb. that just confirms fuses are good. If i could uderstand the current flow. where and why it ends when switched on. I have a new battery I can substitute or take this one to advance auto.
Ron Ryman is offline
post #22 of 31 (permalink) Old 06-05-2019, 11:44 PM Thread Starter
No, sounds like you did it right, don't join the two on the plug.
Maybe I misread the other post.
Seems like either the battery is dropping off as soon as any load is put on it. Or, the grounds won't support the current when the switch is on.
Hook a set of jumper cables from a car battery and see how it behaves. Don't jump it from a running car.
If it's still the same, check those grounds off the battery, check both ends.
gotcha
post #23 of 31 (permalink) Old 06-05-2019, 11:49 PM Thread Starter
gotcha
I also unhooked the R/R. thats what charges the battery Can I leave it unhooked for this test. or plug it back in. im closing in.
post #24 of 31 (permalink) Old 06-05-2019, 11:52 PM
Plug it back in.
Ron Ryman likes this.
post #25 of 31 (permalink) Old 06-06-2019, 02:49 AM Thread Starter
Plug it back in.
That was the final solutionafter grinding the 2 grounds at the battery and jumping from the car battery she lit up like a Christmas tree!! I did the blue wire mod. with the needle. switching blue wire to open pin below blue one. de rusted and painted the battery box. tomorrow I will get a new battery and put the original selinoid back on. Thank you for your kindness consideration. and patience. Question How important is an R/R upgrade. would it prevent future stator failure???
post #26 of 31 (permalink) Old 06-06-2019, 02:57 AM
Glad you got it working.
If an R/R fails, it'll likely take the stator with it, which you definitely don't want. If there's any question about the solidity of your R/R, I'd replace with a mosfet type. They only last so long before they give out, so if you're on an older bike with an original R/R, it's worth it.
Vulcan slang for newcomers
Service Manual Download
Thorn is offline
post #27 of 31 (permalink) Old 06-06-2019, 08:00 AM
That's good news, and you're welcome! Wish I'd thought of that sooner though. I finally kept thinking I'd seen this before, battery or a cable connection.
I put a lot of blame on the JB and it's relays for the stator problems, but my bike had a dead stator and r/r when I bought it. You've already bypassed two of those relays. About $100-125 should get you a good MOSFET R/R, but I haven't shopped around lately.
The AGM type battery is worth the extra money, especially on this bike, it's sensitive to low cranking voltage. The AGM cures a lot of the starting problems.
post #28 of 31 (permalink) Old 06-06-2019, 01:37 PM Thread Starter
Would you recomend a D.B.R/R.? OR OTHER BRAND. why is the mosfit the best choice?
post #29 of 31 (permalink) Old 06-06-2019, 01:41 PM Thread Starter
So AGM is not a brand but the type of glass pak or gel inside? would a new D.b brand R/R be a good choice or not worth the price savings. Do you use facebook at all? I would like to keep in contact with you.
post #30 of 31 (permalink) Old 06-06-2019, 02:13 PM
No, I'm not on FB.
AGM = Absorbed Glass Mat , it's a better type of battery than wet cell or gel.
Not sure what D.b. is. ?? Some have reported trouble with really cheap R/Rs.
The MOSFET type r/r is better than stock at processing the current. Some here will recommend a Series type r/r as well, but my experience is with the MOSFET. I've only had to buy one.
This is where I bought mine: https://roadstercycle.com/ I see he's offering series type also, but it's more expensive.
This is the kit I used: FH020AA ... It's larger than stock so I mounted it behind the left sidecover. It's a better mounting spot anyway, as long you don't blow a lot of fuses. it gets better air flow and a lot less exhaust heat.
