VN 750 Decompression Valve - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 2Likes
  • 2 Post By Thorn
post #1 of 6 (permalink) Old 05-26-2019, 04:11 PM Thread Starter
Hi All,
Does my 1993 VN750 have a decompression value? if yes, where is it?
My bike struggles to turn over and I've been reading about why this might be and came across a few posts about Vulcan 1500/ 2000 that have decompression values which get stuck open and make the bike hard to turn over/ start.
Thanks in advance.
Pete
Swinpy22 is offline
post #2 of 6 (permalink) Old 05-26-2019, 05:56 PM
No decompression valve on the 750. First thing to do for this bike would be to get the battery tested, and if it's not in really good condition, replace with an AGM. An old battery even fully charged might not have enough oomph.
Chris and Shim and Spockster like this.
Vulcan slang for newcomers
Service Manual Download
Thorn is offline
post #3 of 6 (permalink) Old 05-26-2019, 07:06 PM
Retired USAF (IYAAYAS)
Chris and Shim's Avatar
I concur. For some reason this species machine does not like regular, wet batteries. The bike will seem hard to start even if the battery shows good readings. AGM-type batteries fix the issue (as long as it IS a battery only issue). An AGM battery can make all the difference in the world.
Saddlebags, hard mounted
Fork mounted tool bag (now hard mounted)
Relocated rear turn signals
LED turn signals, brake lights and running lights
LED license plate frame
Engine Guard and Highway pegs
National Cycles Low Boy Heavy Duty windshield
Home made lowers (nice)
Custom seat (made by a local guy)
Iridium plugs (DPR7EIX-9)
Shenko 230 Tour Master tires at 11,123 miles
Splines lubed at 11,123 miles
Luggage rack
Light bar with LED lights
Chris and Shim is offline
post #4 of 6 (permalink) Old 05-27-2019, 03:57 AM Thread Starter
thanks for the info guys, much appreciated
Thanks,
Pete
Swinpy22 is offline
post #5 of 6 (permalink) Old 05-27-2019, 04:38 AM
See original post
trev uk is offline
post #6 of 6 (permalink) Old 05-27-2019, 11:26 PM
I am on my 3rd Vulcan 750. First two were bought new. one peculiar thing I noticed about all of them is how slowly they turned over, even when connected to a big truck battery (12V) with way more amperage than the VN750 starter needs. This is common for long stroke motors, like a Harley, or my Royal Enfield Bullet, but the VN750 has an ultra short stroke motor, and should spin over very fast with a good battery. But it doesn't. I don't know if the starter simply lacks enough power or what. The VN750 has always had hard starting problems, both warm and cold. I've heard a lot of theories about why, but nobody has ever figured it out to my knowledge. The Vulcan 750 has a lot of quirks and problems, if it were some other bike most owners would quickly get rid of them. The thing is, when they work properly, they work really good, and a lot of solutions have been found for their various problems. I live in AZ, the land of HOT, and I found that leaving the choke off, opening the throttle all the way, cranking it a couple of turns, then closing the throttle and hitting the starter button starts it right up. But while these bikes have a lot of common issues, they are also not exactly alike. What works with one may not work with another.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is online now
