New Purchase - 1993 Kawasaki Vn 750 - Page 4 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #31 of 40 (permalink) Old 05-29-2019, 07:52 AM
Just put it on the back burner for a bit and even if you take it to a bike mechanic they would need to strip it to find the problem you could do this yourself for free they are a little more complex having 4 cam chains but like I said it's not rocket science it's just a matter of finding out we're the metal flakes have come from if you do any advice if you get round to it in the future don't hesitate to get in touch
Ps forgot to add it took me nearly 4 years to complete mine with other projects on the go but we'll worth it they are a great ride
trev uk is offline
post #32 of 40 (permalink) Old 05-29-2019, 08:10 AM Thread Starter
Ok many thanks for the offer. I really appreciate all the help so far.
Thanks,
Pete
Swinpy22 is offline
post #33 of 40 (permalink) Old 05-29-2019, 09:50 AM
Jason Pittenger's Avatar
Originally Posted by Swinpy22 View Post
Would the engine out of a 1990 vn 750 fit in my 1993 bike?
To my knowledge, they were cross compatible from '86 to '05. The '85 700cc might even fit.
'89 Vulcan 750 Bought 4/12/18 @ 17805.9 miles $800
Purchased stock. Wrecked once
22490.0+ miles
Completed modifications:
Removed mufflers, straight pipes out of GB
110/90 Front Tire
Pick-up coil re-gapped to .020"
Compufire 55402 r/r series regulator
USB Outlet + Voltmeter
Repainted Metallic Blue w/ new tank bages
Ear Shave (wo/ coasters) 40/140 NO shims 45MPG
MCCT conversion
Planned modifications:
Custom LED turn signals
Highway Pegs
(Possible) ignition advance
Jason Pittenger is offline
post #34 of 40 (permalink) Old 05-29-2019, 10:46 AM
calebj's Avatar
Yep - I don't think there's anything about the 700 that would be a problem. It's amazing how little Kawasaki touched these things over two decades.
1986 VN750 27k miles
1999 EN500 32k
1983 GL650i in pieces. Someday it will ride again.
calebj is offline
post #35 of 40 (permalink) Old 05-30-2019, 04:04 AM Thread Starter
What would someone's best guess be for the total PARTS only cost for a full engine rebuild (worst case scenario)
Thanks,
Pete
Swinpy22 is offline
post #36 of 40 (permalink) Old 05-30-2019, 05:34 AM
A rough guess the gaskets about£100 4 cam chains at £20 each after that depends on what you find when you open it up
Just had a look cam chains £93 for the 4
trev uk is offline
post #37 of 40 (permalink) Old 05-30-2019, 08:52 AM
If you have the motor open check the stator. The OEM replacement part is pricey. Folks on here have mentioned a few other cheaper alternatives, but the few mechanics I’ve talked to adamantly suggest going with OEM only. Partzilla seems to have the best prices for OEM stuff that I’ve found. Don’t forget gaskets if you decide to do so. Also there’s a section on the forum called “Vulcan Verses” which basically outlines all the “quirks” and known issues for these bikes with fixes and workarounds. I’m taking my bike to a shop today to get the stator replaced because I have no place to tear it down and do it myself. I’m content paying for this repair because I didn’t pay a whole lot for the bike, but this is the last big repair I do before I slap a “For Sale” sign on it lol. Any other big issues pop up then it’ll be time for a trade in. When these bikes run they’re a blast
mmart is online now
post #38 of 40 (permalink) Old 06-05-2019, 05:10 PM Thread Starter
Evening all,
I haven't really done much more work on my bike.
I did however buy a 2nd hand ignition coil which the seller stated was in working order. Im still not getting any spark from either plug in the 2nd cylinder (rear cylinder). The coil is slightly smaller than my original one some I'm wondering if its the wrong coil?
I also took the engine stator cover off again and noticed fragments of metal attached/ attracted to the stator/ flywheel. Can bits of metal get into this area when the engine oil is moving around the engine, or is it likely something has happened to my stator/ flywheel. I appreciate the answer is going to probably be take the stator and flywheel out but I don't have much time to play in the garage at the moment so I thought id ask the question incase anyones had similar issues.
Thanks,
Pete
Swinpy22 is offline
post #39 of 40 (permalink) Old 06-06-2019, 10:54 AM
Pete from what you say the engine needs to come out and taken apart to find out we're the metal parts have come from with the engine out you can take the main outer cases off and have a look if you can't find anything there you would then need to take the cyl heads and barrels off to split the main case if your unsure at all pm your number and I can talk you though it
trev uk is offline
post #40 of 40 (permalink) Old 06-06-2019, 12:26 PM
With the metal shavings the first thing I think of in that area, damper gears. The damper bushings wear or break, then the damper gear rubs against the stator case, eventually making a large hole (pics here somewhere). The engine will vibrate much more than normal.
In the pics of the screen check, it looks like some of the damper bushing material in the mix of debris.
So if you're doing a stator, plan on $40-50 for damper bushings. And don't put the damper gear back on backwards, like I did. Made the bike shake like a paint shaker.
Also, metal shavings on the pickup coils might kill the spark. Might also affect the stator, not sure what testing you've done.
If the damper gear is rubbing, you don't want to start this engine yet.
