Stator question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 05-14-2019, 08:53 PM Thread Starter
Stator question
might already know the answer to this but, my 86 Vulcan 750 is having charging issues, tested the stator, equal resistance across all 3 phases, no short to ground. Running ac voltage a&b is 50 at 3500, a&c is 50, but b &c is 15 volts, bad stator or bad connection? Tested at the r&r plug not the bullet connectors
Lonewolf6491 is offline
post #2 of 5 (permalink) Old 05-19-2019, 04:37 PM
That sounds like your stator is fine. Check your DC voltage at above 3k rpms vs at idle. It should increase to around 13.5-14 iirc and not jump higher
Chris Allunario is offline
post #3 of 5 (permalink) Old 05-19-2019, 06:39 PM
if those readings are correct, then stator is toast. B&C should be approx the same as other pairs.
did you disconnect the r/r before the test? if not, retest with regulator disconnected. if voltage is correct then the r/r is bad. if the 3 voltages are correct (or at least close to each other) the stator is probably ok
post #4 of 5 (permalink) Old 05-19-2019, 06:57 PM
Shouldn't the AC voltage be checked between each stator lead and ground? Versus between each stator lead.
Edit: Answer is no, I checked Denny's guide. Odd, the AC voltage test doesn't appear to be in the repair manual.
Tests should be done with the R/R disconnected, however.
post #5 of 5 (permalink) Old 05-19-2019, 08:47 PM
Check the resistance of the yellow wires. at the bullet connectors. It should be the same. The AC voltage should also be the same for all 3 wires. If it isn't, the stator is bad. With everything hooked up, engine running, and a fully charged battery, the voltage at the battery should be at least 14.5V When I put the rewound stator in my 2003, it was very close to 15V.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
